January 18, 20215 yr Currently controlling fan speed vis BIOS. Trying to configure Dynamix Auto Fan Control. I tried setting up fan sensors for my unRAID box running on a Rampage V Extreme. Followed these instructions: https://wiki.unraid.net/Setting_up_CPU_and_board_temperature_sensing However no luck. Sensors only show core temp. Quote sensors coretemp-isa-0000 Adapter: ISA adapter CPU Temp: +46.0°C (high = +90.0°C, crit = +100.0°C) Core 0: +37.0°C (high = +90.0°C, crit = +100.0°C) Core 1: +36.0°C (high = +90.0°C, crit = +100.0°C) Core 2: +42.0°C (high = +90.0°C, crit = +100.0°C) Core 3: +37.0°C (high = +90.0°C, crit = +100.0°C) Core 4: +38.0°C (high = +90.0°C, crit = +100.0°C) Core 5: +36.0°C (high = +90.0°C, crit = +100.0°C) It found these two drivers using sensors-detect. Quote #----cut here---- # Chip drivers modprobe coretemp modprobe nct6775 /usr/bin/sensors -s #----cut here---- root@Tower:~# sensors coretemp-isa-0000 Adapter: ISA adapter CPU Temp: +46.0°C (high = +90.0°C, crit = +100.0°C) Core 0: +37.0°C (high = +90.0°C, crit = +100.0°C) Core 1: +36.0°C (high = +90.0°C, crit = +100.0°C) Core 2: +42.0°C (high = +90.0°C, crit = +100.0°C) Core 3: +37.0°C (high = +90.0°C, crit = +100.0°C) Core 4: +38.0°C (high = +90.0°C, crit = +100.0°C) Core 5: +36.0°C (high = +90.0°C, crit = +100.0°C) root@Tower:~# sensors-detect # sensors-detect version 3.6.0 # System: ASUS All Series # Board: ASUSTeK COMPUTER INC. RAMPAGE V EXTREME # Kernel: 4.19.107-Unraid x86_64 # Processor: Intel(R) Core(TM) i7-5930K CPU @ 3.50GHz (6/63/2) This program will help you determine which kernel modules you need to load to use lm_sensors most effectively. It is generally safe and recommended to accept the default answers to all questions, unless you know what you're doing. Some south bridges, CPUs or memory controllers contain embedded sensors. Do you want to scan for them? This is totally safe. (YES/no): YES Silicon Integrated Systems SIS5595... No VIA VT82C686 Integrated Sensors... No VIA VT8231 Integrated Sensors... No AMD K8 thermal sensors... No AMD Family 10h thermal sensors... No AMD Family 11h thermal sensors... No AMD Family 12h and 14h thermal sensors... No AMD Family 15h thermal sensors... No AMD Family 16h thermal sensors... No AMD Family 17h thermal sensors... No AMD Family 15h power sensors... No AMD Family 16h power sensors... No Hygon Family 18h thermal sensors... No Intel digital thermal sensor... Success! (driver `coretemp') Intel AMB FB-DIMM thermal sensor... No Intel 5500/5520/X58 thermal sensor... No VIA C7 thermal sensor... No VIA Nano thermal sensor... No Some Super I/O chips contain embedded sensors. We have to write to standard I/O ports to probe them. This is usually safe. Do you want to scan for Super I/O sensors? (YES/no): YES Probing for Super-I/O at 0x2e/0x2f Trying family `National Semiconductor/ITE'... No Trying family `SMSC'... No Trying family `VIA/Winbond/Nuvoton/Fintek'... Yes Found `Nuvoton NCT6791D Super IO Sensors' Success! (address 0x290, driver `nct6775') Probing for Super-I/O at 0x4e/0x4f Trying family `National Semiconductor/ITE'... No Trying family `SMSC'... No Trying family `VIA/Winbond/Nuvoton/Fintek'... No Trying family `ITE'... No Some systems (mainly servers) implement IPMI, a set of common interfaces through which system health data may be retrieved, amongst other things. We first try to get the information from SMBIOS. If we don't find it there, we have to read from arbitrary I/O ports to probe for such interfaces. This is normally safe. Do you want to scan for IPMI interfaces? (YES/no): YES Probing for `IPMI BMC KCS' at 0xca0... No Probing for `IPMI BMC SMIC' at 0xca8... No Some hardware monitoring chips are accessible through the ISA I/O ports. We have to write to arbitrary I/O ports to probe them. This is usually safe though. Yes, you do have ISA I/O ports even if you do not have any ISA slots! Do you want to scan the ISA I/O ports? (yes/NO): yes Probing for `National Semiconductor LM78' at 0x290... No Probing for `National Semiconductor LM79' at 0x290... No Probing for `Winbond W83781D' at 0x290... No Probing for `Winbond W83782D' at 0x290... No Lastly, we can probe the I2C/SMBus adapters for connected hardware monitoring devices. This is the most risky part, and while it works reasonably well on most systems, it has been reported to cause trouble on some systems. Do you want to probe the I2C/SMBus adapters now? (YES/no): YES Using driver `i2c-i801' for device 0000:00:1f.3: Wellsburg (PCH) Module i2c-dev loaded successfully. Next adapter: SMBus I801 adapter at 0580 (i2c-0) Do you want to scan it? (YES/no/selectively): YES Client found at address 0x48 Probing for `National Semiconductor LM75'... No Probing for `National Semiconductor LM75A'... No Probing for `Dallas Semiconductor DS75'... No Probing for `National Semiconductor LM77'... No Probing for `Analog Devices ADT7410/ADT7420'... No Probing for `Analog Devices ADT7411'... No Probing for `Maxim MAX6642'... No Probing for `Texas Instruments TMP435'... No Probing for `National Semiconductor LM73'... No Probing for `National Semiconductor LM92'... No Probing for `National Semiconductor LM76'... No Probing for `Maxim MAX6633/MAX6634/MAX6635'... No Probing for `NXP/Philips SA56004'... No Probing for `SMSC EMC1023'... No Probing for `SMSC EMC1043'... No Probing for `SMSC EMC1053'... No Probing for `SMSC EMC1063'... No Client found at address 0x53 Probing for `Analog Devices ADM1033'... No Probing for `Analog Devices ADM1034'... No Probing for `SPD EEPROM'... No Now follows a summary of the probes I have just done. Just press ENTER to continue: Driver `nct6775': * ISA bus, address 0x290 Chip `Nuvoton NCT6791D Super IO Sensors' (confidence: 9) Driver `coretemp': * Chip `Intel digital thermal sensor' (confidence: 9) Do you want to generate /etc/sysconfig/lm_sensors? (yes/NO): NO To load everything that is needed, add this to one of the system initialization scripts (e.g. /etc/rc.d/rc.local): #----cut here---- # Chip drivers modprobe coretemp modprobe nct6775 /usr/bin/sensors -s #----cut here---- You really should try these commands right now to make sure everything is working properly. Monitoring programs won't work until the needed modules are loaded. Unloading i2c-dev... OK Obviously the driver does not exist or is not being detected, Is there an alternative? Edited January 18, 20215 yr by exist2resist
January 19, 20215 yr Author I found this.... https://github.com/lm-sensors/lm-sensors/issues/10 How do I go about booting my system with; acpi_enfore_resources=lax ? Do I just paste the line in go file? Resolved; needed to edit /boot/syslinux/syslinux.cfg file Added acpi enforce resources to the first label Here is what it looks like. I can now read my PWM fans. cat /boot/syslinux/syslinux.cfg default menu.c32 menu title Lime Technology, Inc. prompt 0 timeout 50 label Unraid OS menu default kernel /bzimage append acpi_enforce_resources=lax initrd=/bzroot label Unraid OS GUI Mode kernel /bzimage append initrd=/bzroot,/bzroot-gui label Unraid OS Safe Mode (no plugins, no GUI) kernel /bzimage append initrd=/bzroot unraidsafemode label Unraid OS GUI Safe Mode (no plugins) kernel /bzimage append initrd=/bzroot,/bzroot-gui unraidsafemode label Memtest86+ kernel /memtest Edited January 19, 20215 yr by exist2resist
