Mini SAS 36 Pin to Mini SAS 36 Pin Cable w/ Nylon Tube - $9.95
I just got my shipment of 4 of these cables.  I really wanted to buy form Newegg but @ $12.00 each and $6.49 shipping I decided to look elsewhere:
http://cgi.ebay.com/Mini-SAS-36-Pin-Mini-SAS-36-Pin-Cable-w-Nylon-Tube-/170423774663?pt=LH_DefaultDomain_0&hash=item27ae0c6dc7
I wanted a cable that specifically said "Multilane" in teh description since I wasn't sure if that is the case with all mini-sas cables.
Anyway, cables are very well constructed, about 20" long and shipping is very reasonable ($1.45 expedited and multi product discounts apply).
Just thought I would pass this along.
John
What are you using this for, if i may ask. I know about the sas breakout cable to SataII. But what are you using this for?
Good looking deal.
This cable is used when you have a card such as the AOC-SASLP-MV8 and have a backplane that has the same connection. The backplane is what the SATA drives plug into, so there is no need for a breakout cable.
The Norco Cases are a prime example of this.
Exactly.  I have 2x AOC-SASLP-MV8  and a Norco RPC-4220 case.
Ohhh...and the 4 SATA ports in the MB...I use a reverse breakout cable.
John
Thanks for the insight guys!
Followup...
I installed 4 of these last night.  I then copied 4TB of data across 9 drives as a test.  No errors.  Cables performed as expected.
John
Heck, my end goal is to get a Norco one day, so at this price, I just bought 2 :)
Thanks for posting!
