Question about power supply and hard drives....
I purchased this Seasonic X660W Power Supply for my 15 drive system. The one bad thing is i'm only using Western Digital Black drives. Right now I have 3 2TB Black drives and 6 1TB Black drives. Is this power supply going to be able to handle all this 24/7 running most of the time?
Here are the power supply specs, and then I'll list the HD specs below that. I just listed WATTS, as I don't know much about the amps stuff. I know maybe some of our pro builders here can comment perfectly about this.
Thanks!
      Specifications
          o Mfr Part Number: X-660(SS-660KM)
          o Features:
                + 80PLUS Gold Certified Super High Efficiency
                + Seasonic DC Connector Module with Integrated Voltage Regulator Module
                + DC to DC Converter Design
                + Seasonic Hybrid Silent Fan Control
                + Sanyo Denki - San Ace Silent Fan
                + Conductive Polymer Aluminum Solid Electrolytic Capacitors
                + Highly Reliable 105°C Grade A Capacitors
                + Tight Voltage Regulation (±3%)
                + Active Power Factor Correction (99% PF Typical)
                + High +12V Output
                + High Current Gold Plated Terminals
                + Dual Sided PCB Layout
                + Ultra Ventilation (Honeycomb Structure)
                + Full Modular Cabling Design
                + Multi-GPU Technologies Supported
                + All-in-One DC Cabling Design
                + Easy Swap Connector
                + Universal AC Input (Full Range)
                + 5 Years Warranty
          o Total Power: 660 W
          o Power Factor Correction: Active PFC, 99% typical
          o Safety: CB, cTUVus, CCC, TUV, GOST-R, BSMI, CE, UKR, FCC, C-tick
          o Output: +3.3V @ 25A, +5V @ 25A, +12V @ 54A, -12V @ 0.5A, +5Vsb @ 3A
          o Input Voltage : Full Range- 100 - 240V (Max. 90 - 264V)
          o Input Frequency Range: 50 ~ 60 Hz
          o Input Current: 8 - 4A
          o Connectors: 1x 20+4-pin Main Power Connector, 1x 4+4-pin EPS 12V Connector; 4 x 6+2-pin PCI-Express Connectors; 5x 4-pin Peripheral Connectors, 8x SATA Connectors, 2x 4-pin FDD Connectors
          o Cooling System: Sanyo Denki Ball Bearing Fan
          o Dimension (WxLxH): 5.9 x 6.3 x 3.4 inch / 150.0 x 160.0 x 86.0 mm
          o RoHS Compliant, SLI Ready
Western Digital Black 2TB x 3
Read/Write 10.7 watts
Idle 8.2 watts
Standby 1.3 watts
Western Digital Black 1TB x 6
Read/Write 8.4 watts
Idle 7.8 watts
Standby 1.00 watts
+12V @ 54A
Estimate 3A per black drive.  You have 9.  That's 27A total.
You are well within the limits.  That PSU could handle a 20+ drive system.
Your PSU laughs at your feeble attempts to overload it :D
So that's where the occasional sounds are coming from in my unraid server. :o
+12V @ 54A
Good, that makes me feel much better. Thanks.
