magicman32 Posted August 13, 2021 Share Posted August 13, 2021 Hi All What I am trying to do is have 2 gpus for passthru to 2 seperate vms Problem: Installed 2nd gpu in unraid server (identical amd rx570 8gb cards) when I start a single vm....my vms tab disappears and go to settings vm manger and thats gone too Setup: I have a linux vm and a windows 11 vm installed when it comes to vm setup each vm has its own gpu with seperate id (so I know which card is which), each card has its own iommu group Outcome: My server becomes so unstable to the point I have to reboot, because it freezes so I cant get any logs to see whats wrong........ at first I thought it was a power issue, I started with a 750w psu running 2950x threadripper 6 hdds and 2 amd rx570 8g gpus So I upgraded the psu to a 1000w psu and getting same issues, So I have taken out 2nd gpu and system is now stable once more...... Im not sure if its a setup thing or that I have identical gpus If someone has some insight to dual gpu setup that would be great, Im not sure what to check for in logs.........any help would be greatful, a bit lost and disappointed I cant get this working I have same results with 6.9.2 and now with 6.10 rc1 Quote Link to comment
