drumstyx Posted December 8, 2021 Share Posted December 8, 2021 I'm trying to fine tune my UPS power down and power restored workflows. I run 2 DS4246 disk shelves, and they need to be powered up for a minute or two before unraid boots, to avoid panics about missing disks. I've got a switched PDU, and a UPS with an outlet group. The outlet group on the UPS powers non-critical systems that I want to come back after a power outage, but not only my unraid server, so I can't just switch that off/on based on power status. So I've been working to directly switch the PDU outlets. Honestly, it's a long story, but the bottom line: I need to be able to power up those 2 disk shelves when unraid boots, and then tell it to wait a couple minutes for them to spin up, then continue with mounting the array. My understanding is that the go script runs asynchronously to array booting and mounting, so that's out, and user scripts simply specifies "AT" array start, not whether it's run before or after. What are my options here? Quote Link to comment
itimpi Posted December 8, 2021 Share Posted December 8, 2021 1 hour ago, drumstyx said: My understanding is that the go script runs asynchronously to array booting and mounting, so that's out, and user scripts simply specifies "AT" array start, not whether it's run before or after. Not quite true. The ‘go’ file starts the emhttp server which is what starts all the services and the Unraid GUI, and that can run asynchronousky. Sounds like you could satisfy your need by inserting the long running part to happen before starting emhttp. Quote Link to comment
