May 28, 20224 yr Hello im new to unraid. I have setup my old pc as a plex server with unraid. I have previously ran it with windows. so first off all I cant use my GPU Nvidia geforce GTX titan (the first model), as far as i understand its to old. and now when my buddy tried stream from my server he cant sellect higer then 720p 2mbps. i think ive tired all the plex setting cant get it higer but i can put it to lower setting. pc specs is 3930k, 16gb ram, rampage iv extreme, geforce GTX titan and a samsung 860 evo as cache drive. I use the offical docker container and vertion 6.9.2 of unraid.
May 28, 20224 yr Million variables. Internet speed, your CPU is 11 years old, size of files, whether your friend is in Plex as a Family member or a friend (without a plex pass membership) etc etc.
May 29, 20224 yr Author well basicly it worked fine on windows with the same hardware but now on unraid it dossent. is their anything i can do to find out why. and internet speed is not the problem I have 200mbit down and 50mbit up.
May 30, 20224 yr Author I think I solved it. it was the port forwarding that was an issue I had it set to 32401 and set the same in the router. so I first tired to toggle off UPnP did not help then turned it back on and change plex settings to to automatic port and then it worked
