New Unraid build. Less than 1MB/s read over network, full speed write to array
I have a new unraid build with version 5.0b6a and the following specs:
Processor:          AMD Phenom II X4
Motherboard:      Biostar A780LG3
Ram:                 Kingston 2 GB DDR3 1066
Power Supply:     Corsair CX500
HDDs:                2x 2 TB Seagate LP(1 parity, 1 data)
                       1x 2 TB Samsung F4 (data)
                       1x 1 TB Hitachi Deskstar (cache)
I have flashed the latest firmware for both the Samsung and Seagate HDDs.  I did 2 preclears per drive.  Everything started just fine.  I assigned my drives and created my shares without an issue.
I had no problem transferring files to the array at 90-100MB/s(prior to parity).  With parity, I can still write to the cache at 80 MB/s or directly the array at 30+MB/s.  My problem is with transferring from the Unraid server to my Windows machine.  I can transfer from other places in my network just fine. I'm getting less than 1 MB/s from the Unraid server.
I have attached the syslog, results of ethtool eth0 and the disk performance test from unmenu.
root@Tower:~# ethtool eth0
Settings for eth0:
       Supported ports: [ TP MII ]
       Supported link modes:   10baseT/Half 10baseT/Full
                               100baseT/Half 100baseT/Full
                               1000baseT/Half 1000baseT/Full
       Supports auto-negotiation: Yes
       Advertised link modes:  10baseT/Half 10baseT/Full
       Advertised pause frame use: No
       Advertised auto-negotiation: Yes
       Link partner advertised link modes:  10baseT/Half 10baseT/Full
       Link partner advertised pause frame use: No
       Link partner advertised auto-negotiation: Yes
       Speed: 1000Mb/s
       Duplex: Full
       Port: MII
       PHYAD: 0
       Transceiver: internal
       Auto-negotiation: on
       Supports Wake-on: pumbg
       Wake-on: g
       Current message level: 0x00000033 (51)
       Link detected: yes
Result of disk speed test:
/dev/sda:
Timing cached reads:   3186 MB in  2.00 seconds = 1593.32 MB/sec
Timing buffered disk reads:  338 MB in  3.01 seconds = 112.35 MB/sec
/dev/sdb:
Timing cached reads:   3182 MB in  2.00 seconds = 1590.70 MB/sec
Timing buffered disk reads:  402 MB in  3.01 seconds = 133.55 MB/sec
/dev/sdc:
Timing cached reads:   3122 MB in  2.00 seconds = 1560.35 MB/sec
Timing buffered disk reads:  340 MB in  3.00 seconds = 113.18 MB/sec
/dev/sdd:
Timing cached reads:   3096 MB in  2.00 seconds = 1548.24 MB/sec
Timing buffered disk reads:  250 MB in  3.02 seconds =  82.82 MB/sec
syslog-2011-06-08.txt
What about Ethernet errors? What do you get from ifconfig eth0 or ethtool -S eth0 after one of your tests?
I don't know what happened but suddenly it's working without changing anything, not even a restart.  Those commands showed no errors.  I'll check it regularly over the next couple of days to see if it comes back but for now, oddly, it's fine.
