October 21, 20224 yr I have upgraded my drives during last months. Replaced few 8tb drives with more capacity drives. And added higher capacity Parity drives. But they parity drives are disabled after successful rebuild and running with no errors few days, the disk are disabled. I tried to run the array in maint mode and run checks on drives but is shows no error. Appreciate help in finding what is causing this. I have swapped the cables, moved the SATA ports etc. here is diag zip file https://drive.google.com/drive/folders/1M1cmY2q_4IL5oADPl3vTZxD6HuGlJuhe?usp=sharing
October 24, 20224 yr Marvell controllers are not recommended but might be OK if IOMMU is disabled. How are these drives connected? Both parity disks look OK and since it is only parity no harm in rebuilding to same disks. Check connections first. https://wiki.unraid.net/Manual/Storage_Management#Rebuilding_a_drive_onto_itself syslog spammed with these, can you make them go away? Oct 20 17:17:56 813Unraid usb_manager: Info: rc.usb_manager usb_remove PixArt_HP_USB_Optical_Mouse /dev/bus/usb/001/006 001 006 Oct 20 17:17:56 813Unraid usb_manager: Info: rc.usb_manager Device Match 001/006 vm: 001 006 Oct 20 17:17:56 813Unraid usb_manager: Info: rc.usb_manager Removed 001/006 vm: nostate 001 006 Oct 20 17:17:58 813Unraid kernel: usb 1-13: new low-speed USB device number 7 using xhci_hcd Oct 20 17:17:58 813Unraid kernel: input: PixArt HP USB Optical Mouse as /devices/pci0000:00/0000:00:01.3/0000:02:00.0/usb1/1-13/1-13:1.0/0003:04F2:0923.0006/input/input9 Oct 20 17:17:58 813Unraid kernel: hid-generic 0003:04F2:0923.0006: input,hidraw0: USB HID v1.11 Mouse [PixArt HP USB Optical Mouse] on usb-0000:02:00.0-13/input0 Oct 20 17:17:58 813Unraid usb_manager: Info: rc.usb_manager usb_add PixArt_HP_USB_Optical_Mouse /dev/bus/usb/001/007 001 007 Oct 20 17:17:59 813Unraid usb_manager: Info: rc.usb_manager Autoconnect Parent usb1 Oct 20 17:17:59 813Unraid usb_manager: Info: rc.usb_manager Autoconnect No Mapping found PixArt_HP_USB_Optical_Mouse /dev/bus/usb/001/007 001 007 port 1-13 Oct 20 17:18:47 813Unraid kernel: usb 1-13: USB disconnect, device number 7
October 24, 20224 yr No need for more than default 1G libvirt.img, and probably docker.img is larger than needed. 20G is often enough, have you had problems filling it?
