January 2, 20233 yr Hi all, This morning I noticed some problems on my network (internet access up but DNS down). I use Adguard Home for my DNS. UNRAID webgui is unresponsive but SSH yes. Some dockers work well (tailscale for example) some others don't work at all (unifi-controller, adguard, ...). I've tried to reboot server without a change. "My Servers" seems to work well but I didn't activate remote access. I've seen some bad words in syslog (attached). Someone can help me to solve this weird issue ? syslog_unraid.txt
January 2, 20233 yr Author 2 minutes ago, JorgeB said: Please post the diagnostics. Could you help me generate diagnostics without webui (broken)
January 2, 20233 yr Author My fault I haven't seen "diagnostics" command. I've sent you the file by PM (maybe with some private data)
January 2, 20233 yr Community Expert You can post the anonymized diags, pleas post them here instead, this way other users can also help, I'm not always available.
January 2, 20233 yr Community Expert There's filesystem corruption detected: Jan 2 06:55:31 nas kernel: BTRFS critical (device nvme0n1p1): corrupt leaf: root=2 block=50997444608 slot=32, unexpected item end, have 2467418972 expect 14587 Suggest backing up then reformatting this fs.
January 2, 20233 yr Author It seems to refer to one disk (nvme) of my two-disk cache (1 x nvme and 1 x SATA SSD). Could you help me solve this issue ? Can I simply remove the nvme disk (redundancy), format it (or replace if faulty) and "rebuild" the FS ? Thank you for your help Edited January 2, 20233 yr by denisvic
January 2, 20233 yr Community Expert This is a filesystem problem, not a device issue, in these cases I usually recommend backup and reformatting to avoid future issues, but if you want you can try a filesystem repair, but only after backing up all you can since it might make things worse.
January 2, 20233 yr Author I've backed up my data, how now can I format the cache without GUI ?? Thank you for your help
January 3, 20233 yr Community Expert Disable array auto-start by editing disk.cfg on your flash drive (config/disk.cfg) and changing startArray="yes" to "no", then reboot and should have GUI access.
