January 31, 20233 yr Hi, I'm having slow / bursty speeds trying to read from my unraid server on my Mac, and am not sure where to start to diagnose the issue. As you can see from the Mac throughput graph, it bursts between 1-2MB/s to 72ish MB/s continuously. Copying from another Mac or PC over the same network is fast, and the issue is the same wether I'm on a wired gigabit or wireless network. Where would I start? CPU Usage on the server appears OK, what else should I be looking at? Diagnostics are attached.. Thanks for your help! chasm-diagnostics-20230131-1654.zip
