(SOLVED) Passedthrough (system devices) NVME disappeared, please help.
Amongst numerous issues even getting windows installed, passing through my 3070 (get to that later), I passed through a nvme drive to use as my boot drive/C drive for my windows 11 VM because I thought that might be better than a Vdisk like I've used in the past and after a failed VM (internal error: Unknown PCI header type '127' for device '0000:02:00.0') launch, it disappeared from both the (new) VM template and apparently system devices.  I am no expert, but I have never had this much trouble with Unraid.  I have recently started a new build with a Xeon and X99, maybe that's been the issue.  Anyway I'll attach the vfio log and my diagnostics.  I would really like this disk back then I can tackle all the other issues I've had with my still uncreated VM.  Thanks.
text  error  warn  system  array  login
Loading config from /boot/config/vfio-pci.cfg
BIND=0000:00:1b.0|8086:8d20 0000:02:00.0|1987:5016 0000:03:00.0|1106:3483 0000:05:00.0|10de:2484 0000:05:00.1|10de:228b 0000:08:00.0|8086:08b3 0000:09:00.0|1b21:1242
Processing 0000:00:1b.0 8086:8d20
Vendor:Device 8086:8d20 found at 0000:00:1b.0
IOMMU group members (sans bridges):
/sys/bus/pci/devices/0000:00:1b.0/iommu_group/devices/0000:00:1b.0
Binding...
Successfully bound the device 8086:8d20 at 0000:00:1b.0 to vfio-pci
Processing 0000:02:00.0 1987:5016
Error: Device 0000:02:00.0 does not exist, unable to bind device
Processing 0000:03:00.0 1106:3483
Vendor:Device 1106:3483 found at 0000:03:00.0
/sys/bus/pci/devices/0000:03:00.0/iommu_group/devices/0000:03:00.0
Binding...
Unbound 0000:03:00.0 from xhci_hcd
Successfully bound the device 1106:3483 at 0000:03:00.0 to vfio-pci
Processing 0000:05:00.0 10de:2484
Vendor:Device 10de:2484 found at 0000:05:00.0
/sys/bus/pci/devices/0000:05:00.0/iommu_group/devices/0000:05:00.0
/sys/bus/pci/devices/0000:05:00.0/iommu_group/devices/0000:05:00.1
Binding...
Successfully bound the device 10de:2484 at 0000:05:00.0 to vfio-pci
Processing 0000:05:00.1 10de:228b
Vendor:Device 10de:228b found at 0000:05:00.1
/sys/bus/pci/devices/0000:05:00.1/iommu_group/devices/0000:05:00.0
/sys/bus/pci/devices/0000:05:00.1/iommu_group/devices/0000:05:00.1
Binding...
0000:05:00.0 already bound to vfio-pci
0000:05:00.1 already bound to vfio-pci
Successfully bound the device 10de:228b at 0000:05:00.1 to vfio-pci
Processing 0000:08:00.0 8086:08b3
Vendor:Device 8086:08b3 found at 0000:08:00.0
/sys/bus/pci/devices/0000:08:00.0/iommu_group/devices/0000:08:00.0
Binding...
Successfully bound the device 8086:08b3 at 0000:08:00.0 to vfio-pci
Processing 0000:09:00.0 1b21:1242
Vendor:Device 1b21:1242 found at 0000:09:00.0
/sys/bus/pci/devices/0000:09:00.0/iommu_group/devices/0000:09:00.0
Binding...
Unbound 0000:09:00.0 from xhci_hcd
Successfully bound the device 1b21:1242 at 0000:09:00.0 to vfio-pci
vfio-pci binding complete
Devices listed in /sys/bus/pci/drivers/vfio-pci:
lrwxrwxrwx 1 root root    0 Feb  1 03:40 0000:00:1b.0 -> ../../../../devices/pci0000:00/0000:00:1b.0
lrwxrwxrwx 1 root root    0 Feb  1 03:40 0000:03:00.0 -> ../../../../devices/pci0000:00/0000:00:02.0/0000:03:00.0
lrwxrwxrwx 1 root root    0 Feb  1 03:40 0000:05:00.0 -> ../../../../devices/pci0000:00/0000:00:03.0/0000:05:00.0
lrwxrwxrwx 1 root root    0 Feb  1 03:40 0000:05:00.1 -> ../../../../devices/pci0000:00/0000:00:03.0/0000:05:00.1
lrwxrwxrwx 1 root root    0 Feb  1 03:40 0000:08:00.0 -> ../../../../devices/pci0000:00/0000:00:1c.3/0000:08:00.0
lrwxrwxrwx 1 root root    0 Feb  1 03:40 0000:09:00.0 -> ../../../../devices/pci0000:00/0000:00:1c.4/0000:09:00.0
drizzt-diagnostics-20230131-2201.zip
Edited by Hardware Dynasty
Only the cache NVMe device is being detected by Linux, this is not a software issue, try re-seating the other one or using a different PCIe slot.
The nvme reappeared after a reset (which I swear I tried already).  Might've been a pcie issue.
  • Hardware Dynasty changed the title to (SOLVED) Passedthrough (system devices) NVME disappeared, please help.
