July 19, 20233 yr I am in the process of upgrading my Parity and Array drives from 3TB & 4TB WD Red (SMR) to Iron Wolf 8TB CMR drives. After installing the 8TB and running parity checks and zeroing the array drives, I am getting hard drive temperature alerts between 45C and 49C for the Iron Wolfs which I never had with the WD drives. Most of my drives live in a Norco SS-500 cage. The other is a Rosewill RSV-SATA-Cage-34. I only have 2x 8TB Iron Wolf drives and 2x SSDs in the Norco bay. I began researching and scanned through a lot of the posts regarding the Norco SS-500 and mostly all of the information was regarding adding a quiet fan. My concern is not noise but cooling. I found a good blog post -- http://greenleaf-technology.com/new-norco-ss-500-5-in-3-drive-cage-review/ and the stock fan is a KENON Motors, DC Brushless, Model KMF08DHHD1B which I cannot find any specs on. Another commenter said their stock fan was a Delta Electronics, model AFB0812H. Which those specs are "12 volts, with an operating range of 7 V to 13.8 V, 3000 RPM, 35.31 CFM, maximum air pressure 4.04 mm of water. Noise rating of 31 db". With those specs not even the Noctua NF-A8 PWM has that high of cooling rating: mm --> 80x80x25 RPM --> 2200 dB(A) --> 17,7 m³/h --> 55,5 (32.67 CFM) mm H2O --> 2,37 I believe I have the latest Norco SS-500 with the plastic back housing. UPDATE: I took apart my Norco SS-500 and found that the fan had been previously replaced with a Noctua NF-R8 (specs below). I ordered a Bgears b-BlasterPWM 80mm which maxes at 98 CFM and 9.5mmH20 static pressure. I will be drilling a hole in the back of the SS-500 and controlling the fan from the motherboard. Noctua NF-R8 mm --> 80x80x25 RPM --> 1800 db(A) --> 17,1 m³/h --> 53,3 (31.37) mm H2O --> 1,41 plug --> 3-pin Edited July 21, 20233 yr by MickMorley SS-500 fan
December 2, 20232 yr Well if noise is not an issue. I find my NF-A8's to be too loud already. I use four SS-500's.
