[SOLVED - GREMLINS IN THE MACHINE] usb flash problem, parity invalid.. sigh
beta 11
So I stopped the array today, rebooted and then started the array.
The flash was showing this
flash  [browse /boot (flash device)] Voyager - 591.77 EB 3.92 GB 578146269403831392 3216764820
So very weird... and then I noticed it said parity invalid also?
Then I noticed onlu some shares had loaded..
Then I noticed when I tried to access the flash via smb it was blank....
It was a new corsair voyager, doubt there is a fault with it, been working fine for 2 weeks..
Anyone know why this happens?
I am not sure what to do, I guess I remove the flash and leave unraid running, see if I can copy everything to the flash again.. then restart unraid I guess..
Sucks having to rely on flash and guid's... heh
Do oyu have some add on that writes to the flash? That has caused problems for me in the past.
No... Only addon extra thing I have ever added to unraid is umenu and I haven't installed any extra packages with unmenu.
Ok so I ripped the card out of the machine and plugged it into my windows machine, all files seem perfect..
So I put it back in the unraid machine and telnet into the unraid machine, going to /boot shows no files at all...
I then decide to take a gamble and reboot..
Then it starts up normal as if nothing had ever happened...
put it down to gremlins?
