October 21, 20233 yr Hi all, I recently configure my unraid connect and its work fine. I configure also WireGuard in unraid and got problem to connect docker. 1. I make config export to file import to WireGuard windows and all work fine. My router is 192.168.1.1 and my docker containers is 192.168.1.10 etc. If my outside network is 192.168.2.1 or other just not that same like my home config is all connection work fine. But if I connect to similar network where first address 192.168.1.1 I can't connect to any docker container. Can somebody can me enplane how I need to change my wireguard config to bypass that and can connect from any IP addresses?
October 22, 20233 yr 17 hours ago, RBK-Serwer said: If my outside network is 192.168.2.1 or other just not that same like my home config is all connection work fine. Change your home network to something unique, like 192.168.142.1 or something.
