October 22, 20233 yr Hi all, I recently upgraded to 6.12.4, and am trying to sort out networking of my server, VMs, WireGuard, and docker containers. My server can't ping 8.8.8.8, which I'm guessing is due to a broken routing table. My home network is 10.22.33.X, and my wireguard network is 10.253.0.X. Can someone with more networking experience help me debug this routing issue for 8.8.8.8? Also, I may have added the 10.253.0.3, .5, .6, .7, .8 while trying to get Wireguard to be able to see the VMs. Can I remove them? PROTOCOL ROUTE GATEWAY METRIC IPv4 default 10.22.33.1 via eth0 1003 IPv4 10.22.33.0/24 vhost0 0 IPv4 10.22.33.0/24 eth0 1003 IPv4 10.253.0.3 wg0 0 IPv4 10.253.0.5 wg0 0 IPv4 10.253.0.6 wg0 0 IPv4 10.253.0.7 wg0 0 IPv4 10.253.0.8 wg0 0 IPv4 172.17.0.0/16 docker0 0 IPv4 172.31.200.0/24 br-e5184ce4c231 0 IPv4 192.168.122.0/24 virbr0 0 System diagnostics attached. storage-diagnostics-20231022-0703.zip
October 23, 20233 yr Author Maybe someone on 6.12.4 who set up a VM with vhost0 networking as per the release notes could post their routing table? That way I could compare. This seems very suspicious to me: IPv4 10.22.33.0/24 vhost0 0 IPv4 10.22.33.0/24 eth0 1003
March 3, 20242 yr I am seeing the same issue (no bridging enabled): eth0 and vhost0 have the same IP and different MACs, so there are 2 route entries here, too
