Jump to content
Unmountable disk and missing cache drive, simultaneously...need help with next steps.
arretx
Situation:  Today, I was adding some power circuits to my house, so before I cut the mains, I shut down Unraid.  Hours later, as I sit down to work on a few things, I notice that when I login, there's no array running due to missing cache drive.
I've been using two NVMe drives, both 1TB, in a mirrored configuration.
I used the reboot feature and it came back with the same problem.  So, I shut the box down completely and powered it back up (something I had already done earlier to accommodate the main power being taken offline.)
This time, it booted with the 2nd cache disk available, but until I unassigned the first and put the 2nd in the first position, I wasn't able to start the array.
So, I started the array and quickly noticed that Disk 1 of the array reports "Unmountable: Wrong or no file system."
This system has 2 parity drives each at 8TB and 5 additional drives in the array for data, etc.  4 are 8TB and 1 is 500GB.  One of those 8TB drives is Disk 1.
Have I lost data at this point?  If so, how do I know what was on Disk 1?  If I replace the disk, will the Array rebuild the data that was on that drive?
2nd concern is the fact that my cache is relegated to a single NVMe disk now.  Should I move all data on the cache to the array then replace the NVMe drive that's faulty (assuming that it is?)
Diags attached.
tower-diagnostics-20231024-2016.zip
Link to comment
I just ran `xfs_repair -v /dev/md1` and was presented with this:
Phase 1 - find and verify superblock...
        - reporting progress in intervals of 15 minutes
        - block cache size set to 3019504 entries
Phase 2 - using internal log
        - zero log...
zero_log: head block 439743 tail block 439417
ERROR: The filesystem has valuable metadata changes in a log which needs to
be replayed.  Mount the filesystem to replay the log, and unmount it before
re-running xfs_repair.  If you are unable to mount the filesystem, then use
the -L option to destroy the log and attempt a repair.
Note that destroying the log may cause corruption -- please attempt a mount
of the filesystem before doing this.
Destroying the log sounds bad.  Should I do this?
Link to comment
  Only 75 emoji are allowed.
  • Create New...
