System Devices No Checkboxes? Help...
Currently I hAVE PCIe ACS Override setting enabled, but under system devices I do not have any checkboxes whatsoever. I am betting it's something simple and probably my fault. Any ideas on getting the checkboxes so I can select my devices for VMs? I tried in Chrome and Edge.
  • 2 months later...
Did you figure it out? in a similar situation
If you click on the Info icon at the top-right of the Unraid GUI does it show that IOMMU is enabled as this is required to pass through devices.   If your system supports it then it is done via a setting in the BIOS.
