disk1 has file system errors - fix common problems
Hello there, I am receiving this error from fix common problems:
disk1 (Samsung_Flash_Drive_0309722050004991-0:0) has file system errors ()
If the disk if XFS / REISERFS, stop the array, restart the Array in Maintenance mode, and run the file system checks. If the disk is BTRFS, then see this post. If the disk is listed as being unmountable, and it has data on it, whatever you do do not hit the format button. Seek assistance HERE
The disc the error is referencing, is just a "dumb" array thumb drive needed to have one big ZFS pool.
I'm just wondering if this is something i can just ignore, since I dont know all possible implications.
Thanks for any insight in advance.
You can ignore, but can also just reformat the device.
