September 8, 20241 yr So long story short - I messed up when adding a new drive and am now having to rebuild a disk. Still can't find the new disk but that's another issue. Yesterday the rebuild was flying along at 120mb/s but from last night it has significantly dropped. Ranging from 5-15mb/s. I shut down all of my dockers except Plex so no writing from any of those. All SMART tests reported no issues on any of the other drives. I have 7 drives connected via mobo and one with an LSI. (One of the 7 isn't currently recognised - separate problem. Probably separate post once rebuild is over - it has no data). Its gone from getting finished in 18 hours to taking 5 days. Any insights would be appreciated. I've checked the logs but to be honest - not too sure what I'm looking for in terms of the dropping speed indicators. tower-diagnostics-20240908-1130.zip Edited September 8, 20241 yr by willow1959
September 8, 20241 yr Community Expert Nothing relevant logged, you can run the diskspeed Docker to confirm all disks are performing normally.
September 10, 20241 yr Author Solution I did figure this out with a lot of digging. My solution was to go to disk settings and adjust the values for: Tunable(md_num_stripes) - Played around a lot but set it at 131072. Make sure you have enough RAM once you start going higher. Tunable(md_queue_limit) - Sat it at 256. Any higher and my rate dropped drastically. Tunable(md_sync_limit) - 20. I read that really any higher than these numbers can improve the quality of the rebuild. With these numbers I jumped from 5-10mb/s up to 110-120mb/s.
