September 12, 20242 yr Recently upgraded to 6.12.13 (more than a week). After starting the system, was greeted with above message. I have tried to reboot multiple times though the array is still offline. ZFS isn't up either. unraidzfs-diagnostics-20240912-1231.zip Edited September 12, 20242 yr by sabertooth Adding more informaiton
September 12, 20242 yr Community Expert I don't see any flash drive related errors, were the diags saved when it was showing it?
September 12, 20242 yr Author Afraid, I saved after the reboot How do I correctly restore installation along with the config?
September 12, 20242 yr Community Expert 1 hour ago, sabertooth said: How do I correctly restore installation along with the config? If you mean the flash config, you can restore from a backup, if available, copy the complete /config folder.
September 12, 20242 yr Author No back-up, but after copying the /config folder, the array doesn't start along with the zfs pool. Will try again
September 12, 20242 yr Community Expert Need the complete page, including why you cannot start the array, there should be an error.
September 13, 20242 yr Author Sorry @JorgeB about the delay in reply. I started to explore various options to restore the zpool. After a fresh install on the same USB drive followed by copy of the /config folder the array would fail to start including the zpool. Manual start of the array would indeed start the main Unraid array though not the zpool based one since same wasn't recognized by Unraid. I had to manually configure the zpool by adding a new pool and adding the existing HDDs to the array. This thankfully restored the zfs pool. Regarding the auto-start issue, apparently the Settings::Disk Settings:Enable auto start was disabled after the first error message (relating to corruption of USB drive). Once enabled array would restart after a reboot. Having said that I believe there is indeed an issue with zpool config restoration after copying over the /config folder.
September 13, 20242 yr Community Expert Possibly the pool cfg files were missing or corrupt, but if I understood correctly, the issue is resolved?
