November 18, 20242 yr Im running into a new problem with rsync transfer speeds. This is only on my local network from my linux pc to my Unraid server. I have a pfsense+ box. Unraid 7.0 beta 4. sudo rsync -vr --ignore-existing -e ssh /home/Videos/folder/"File 1"/ [email protected]:/mnt/user/media/folder/"file s" --progress - example of my code/script I have used the same flags / command for years now and never had an issue. I general get around 180mb transfer speeds. randomly I fire up the transfer and I get basically nothing. usually starts at 100kb then drops to like 3 kb. I randomly keep trying to see if it changes and it did once and I was able to transfer 39 files at normal speeds then it dropped the speed at file 40 and been back down to 3kb again ever since. I don't know enough about all this to know where to even start to look for a solution. google searching has a few things but nothing like what I am experiencing so i figured I would ask if anyone had any ideas.
December 9, 20241 yr I dont know the answer but I also want to state that I am having issues with rsync on 7.0.0 rc1. It runs for hours but then the process hangs and the status stops scrolling but the process is doing something in the background as the disks are still showing activity. This never happened on previous versions of unraid even with rsync sessions that went on for days.
