December 8, 20241 yr I currently have a 6 year old (or older) server using AMD 2700x CPU and a ASRock X370 Professional motherboard and a Quadra 2000. At the time I purchased it because it supported 8 Sata drives and used a lot of smaller size drives. I now have 4 HDD 18TB and two NVME. I primarily use it for plex, file storage and perhaps a VM every now and then. Ideally, I would like the ability to add at least one more HDD. The current system pulls 75-100w all of the time. Which seems silly. I have notice that plex sometimes drags now as I have a large collection. I would like to move to an intel CPU with transcoding to ditch the GPU and get something that will be more power efficient. Its been a long time since I built a system and I am overwhelmed by the combinations. Looking for motherboard and CPU ideas. While not required - wouldn't mind getting a smaller case I have the silverstone 380 ATX case with lots of bay. Thank you so much for your time in reading and answering this! Edited December 8, 20241 yr by dubbly Add more info
August 13, 20251 yr I would look at doing the Ultra 7 265k or the 12 gen i7 or even the 13-14gen i7 will do great. The new 15th gen supports av1.
August 13, 20251 yr I'm still waiting on CPU to assemble but I think I took a power surge and have instability in my amd (x570-d4u 5600x) and decided reluctantly to try Intel - though I'll use the igpu for llms not transcoding (not tequired here).Went asus ws-680-ace ipmi, 14500 for cpu, 64gb ecc. My amd idled around 41w, hoping this'll do better. 5x hdd, 2 ssd, 1 m.2, x710-da2 nic sfp+/dac (on oard ethernet ignored, can't disable).
