Unraid / Plex Container Freezing - possibly related to NVIDIA power save Script?
Hi all,
I’m having an issue where my Plex container randomly freezes and becomes unresponsive. I can’t restart or kill it, and even rebooting the server doesn’t work unless I force it via the command line, which then triggers a parity check.
I recently started using the Spaceinvader NVIDIA power save script, but I’m not sure if it’s the cause.
Diagnostics are attached—any advice is appreciated!
Thanks!
tower-diagnostics-20250127-1745.zip
