March 6, 20251 yr Hi So I don't really know where to post this since I didn't find much searching for whisper-asr-webservice. And I thought/hope this is the least bad place to post. Anyway, it seems that the container is assuming a Nvidia GPU is available (the --gpus all is present in the config) and I wonder if it is possible to use a Intel GPU, or just the CPU? The instructions suggest to add the above --gpus all as extra parameter, but it is already present without adding extra parameter. Is it possible to edit the docker command and remove the --gpus all? Or any other way to just use the CPU?
March 6, 20251 yr Yes,just remove the extra parameter value and it will use the cpu. Just click edit on the container, make sure advanced view is enabled and remove it from ekstra parameters. I found an github issue some time ago talking about igpu ,but I can't remember if someone got it working or not. Will link it tomorrow, on my phone in bed right now. I also found a great script to automate things which I've been using. Haven't used it in a while, but I'll link that too tomorrow. It was working great tho at least in English.
March 7, 20251 yr I can't find the link where they were talking about iGPU, but here is the link to the script I mentioned. https://github.com/ahmetoner/whisper-asr-webservice/issues/93
