Help with ASM1166 and drives not found (already updated firmware)
I swapped out an old LSI HBA for the ASM1166 based on some feedback, hoping it would solve some issues I was having. The drives aren't showing up. I found some posts saying there was a known issue with my chipset so I upgraded the firmware which should fix it.
Looking at something like lspci (I'm far from an expert on the low level hardware stuff) I can see the card at least shows up, but neither of the two drives connected are showing up.
# lspci | grep -i asm
0b:00.0 SATA controller: ASMedia Technology Inc. ASM1166 Serial ATA Controller (rev 02)
I really don't know where to go from here. I've attached my diagnostics, hoping there's some stupid thing somewhere I simply overlooked.
serenity-diagnostics-20250307-0659.zip
There's a disk being detected in that controller, the remaining ports show link down:
Mar  7 06:47:28 Serenity kernel: ata1: SATA link down (SStatus 0 SControl 300)
Mar  7 06:47:28 Serenity kernel: ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Mar  7 06:47:28 Serenity kernel: ata2.00: ATA-9: WDC WD120EFBX-68B0EN0, 85.00A85, max UDMA/133
Mar  7 06:47:28 Serenity kernel: ata2.00: 23437770752 sectors, multi 0: LBA48 NCQ (depth 32), AA
Mar  7 06:47:28 Serenity kernel: ata2.00: Features: NCQ-sndrcv NCQ-prio
Mar  7 06:47:28 Serenity kernel: ata2.00: configured for UDMA/133
Mar  7 06:47:28 Serenity kernel: scsi 3:0:0:0: Direct-Access     ATA      WDC WD120EFBX-68 0A85 PQ: 0 ANSI: 5
Mar  7 06:47:28 Serenity kernel: sd 3:0:0:0: Attached scsi generic sg1 type 0
Mar  7 06:47:28 Serenity kernel: sd 3:0:0:0: [sdb] 23437770752 512-byte logical blocks: (12.0 TB/10.9 TiB)
Mar  7 06:47:28 Serenity kernel: sd 3:0:0:0: [sdb] 4096-byte physical blocks
Mar  7 06:47:28 Serenity kernel: sd 3:0:0:0: [sdb] Write Protect is off
Mar  7 06:47:28 Serenity kernel: sd 3:0:0:0: [sdb] Mode Sense: 00 3a 00 00
Mar  7 06:47:28 Serenity kernel: sd 3:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Mar  7 06:47:28 Serenity kernel: sd 3:0:0:0: [sdb] Preferred minimum I/O size 4096 bytes
Mar  7 06:47:28 Serenity kernel: sdb: sdb1
Mar  7 06:47:28 Serenity kernel: sd 3:0:0:0: [sdb] Attached SCSI disk
Mar  7 06:47:28 Serenity kernel: ata3: SATA link down (SStatus 0 SControl 300)
Mar  7 06:47:28 Serenity kernel: ata4: SATA link down (SStatus 0 SControl 300)
Mar  7 06:47:28 Serenity kernel: ata5: SATA link down (SStatus 0 SControl 300)
Mar  7 06:47:28 Serenity kernel: ata6: SATA link down (SStatus 0 SControl 300)
Swap that disk with another disk from a different port and see where the issue follows, also make sure the disk that are not being detected are spinning up, could be the 3.3v issue (use a molex to SATA adapter to test)
Thanks. Both drives worked previously with the LSI controller, but you're right....one of them needed the molex fix. Maybe that tape was pulled off when I was swapping out cables.
