Setting up my first Unraid NAS need some help with arrays. THANKS!
Hi All,
Im building the nas using the JONSBO N5 case and my old PC parts
Processor    AMD Ryzen 9 5950X 16-Core Processor 3.40 GHz
Installed RAM    64.0 GB
NVIDIA GeForce GTX 1070 (8 GB)
My usage case will be emby server downloading torrents Next cloud and local backup as well as docker apps and stuff.
I will not be running VMs. I will also be using dual 10gb network card connected to Unify Fiber router.
From what I have read ZFS is not capable to upgrade the drives to bigger size later on.
Im looking for suggestion on how to set up the arrays and catche to get good performance.
Im looking for parity as well. Im all new to this Thanks!
Hers is the list of the drives I have available:
Spinning
2x5tb
4x12tb
4x16tb
1x18tb
SSD
1x4tb
1x1tb
Nvme
1x WD_BLACK 1TB SN850 NVMe
Solved by trurl
All spinners in the array, no SSDs or nvme in the array. Parity must be at least as large as the largest array data disk, so 18TB parity.
Since the SSDs are different sizes I would put those in different pools, maybe the 4TB as cache.
nvme, another pool, would be good for the "default" shares that support Dockers/VMs
https://docs.unraid.net/unraid-os/manual/shares/user-shares/#default-shares
Thanks! this is exactly what i needed to know
