Need help building an interactive python docker container
Hi everyone,
I've got a python app that can take a small variety of of launch parameters.
Currently I've built a docker image that works in Unraid, that will run it with default parameters, and output stuff to the log.
That's great, but what I'd love is to launch the image and just have it sit there.
Then you go into the console for it, and actually run the python program from there, with whatever launch parameters you want that time.
I'm sure this is a case of me not knowing much about docker/unraid yet and dabbling in things I don't fully understand.
dockerfile:
FROM python:3.11-alpine3.20
WORKDIR /
RUN apk update && apk add git (needed programs)
RUN adduser -D (username) && mkdir /config /data /app
RUN chown (username):(username)-R /config /data /app
USER (username)
ENV HOME=/config \
TZ=Etc/UTC \
HOSTNAME=(image name)
RUN pip install --upgrade pip
COPY /app/requirements.txt requirements.txt
RUN pip install --no-cache-dir -r requirements.txt
ENTRYPOINT ["/bin/sh", "-c"]
image run command:
docker run -it --name='ImageName' --net='bridge' --pids-limit 2048 -e TZ="America/New_York" -e HOST_OS="Unraid" -e HOST_HOSTNAME="Unraid" -e HOST_CONTAINERNAME="ImageName" -l net.unraid.docker.managed=dockerman -v '/mnt/user/appdata/omb/':'/config/.omb':'rw' -v '/mnt/user/omb/monitored':'/monitored':'rw' -v '/mnt/user/omb/app':'/app':'rw' -v '/mnt/user/omb/init':'/init':'rw' omb -c "bin/sh /init/init.sh"
init.sh:
cd /app
python -u omb # the -u switch makes all print statements go to the log, which we can see in Unraid
Is there a way to modify this to make it not actually fire off a script but just wait, so I can launch the Console for that docker and run it manually?
Edited by theothermatt_b
Solved by primeval_god
I am not sure you need to modify the image at all. I think you could just change the docker run command. Change the CMD portion of the docker run command to something like sleep infinity
and change the -it flag to -d to run the container in detached mode.
Edited by primeval_god
That didn't end up being the fix I used, but you pushed me in the right direction (a lot of times its just like, i don't even know what to search for).
I ended up changing -it to -d -t and removing anything after the image name at all.
Also I removed the ENTRYPOINT line entirely from the dockerfile
Thank you!! (Assuming none of the above was a stupid thing to do for any reason...)
The only trick left is if I could have the console default to the /app directory instead of /
Add another WORKDIR line at the end of the dockerfile. Or use the --workdir option in your run command
That nailed it. Thank you SO MUCH!
