July 6, 20251 yr Hey All, I need a sanity check to make sure I'm selecting the correct parity drive. Had USB hard crash that was fully unrecoverable so had to create a new OS usb drives manually. The creation tool didn't like my usb sticks. I successfully imported my key etc, then realized I have no idea which was my parity drive. I have mounted all the drives as data drives and nothing is assigned as parity currently. I'm thinking its the WDC drive, disk 7, is the parity drive. Disk 5, just shows parent directory and points to other drives which has me a bit confused. Disk 4 I see folder structure like movies/downloads etc, disk 6 same thing just more directories so not those two. Thanks in advance to quell my paranoia of assigning the wrong drive as Parity and for sure lesson learned for writing down my parity drive and probably just taking a screenshot of it to store safely somewhere else along with backingup the USB. Edited July 6, 20251 yr by xGhostx
