July 8, 20251 yr Hi all,I'm trying to passthrough a USB audio device to my W11 VM. In particular, a Razer Barracuda X (wireless, via USB) or a Steelseries Arctis 5 (wired, via USB). No matter what I do, the audio will cut in and out randomly, eventually disconnecting altogether. It can be reset by disconnecting and reconnecting the audio via the USB plugin.I've tried passing it through via the XML template and via the USB plugin. I've also tried reducing some load (by *not assigning the HT core to the VM, even though its isolated). I saw this recommended in another forum, suggesting that the CPU is too busy, so by isolating the cores but not assigning the cores it'll work better. It hasn't worked for me.Any other ideas on how to do this?
