Weird GPU Idle Power Issue
Hello Unraid Community!
I've got a really weird issue I wanted to see if someone had any input on: I recently acquired an RTX 3060 12GB to run a local voice assistant. It is connected to my server via Oculink and works as expected. It consistently reaches P8 idle state without running Spaceinvader's script but the oddity is that sometimes it will idle at 10W and other times at 19W. The system indicates P8 in both cases and I've confirmed the power draw represented in Unraid is accurate via a Sonoff S31 flashed with Tasmota. The higher idle draw happens sometimes after performing more intensive tasks for a few hours, i.e. a MicroWakeWord training container, or if the server has power disconnected and then boots back up with the GPU still connected. I can rectify the issue either by starting up the server with the GPU disconnected/powered off, then shutting down and booting up with it reconnected or in some instances, rebooting the server. I can pretty readily reproduce this. It doesn't appear to be linked to any driver version, as the issue occurs with the open source Nvidia driver and production driver. It also happens if I stop any docker containers that have the GPU passed through. Has anyone experienced anything like? I'm a bit obsessive over minimizing the power draw of my server where possible, so almost double idle power draw is something I'd love to track down. Any help is appreciated!
Edited by obowan
How long does it stay at the higher draw? Do you monitor system temps? My first guess is that it's fans working to cool the system.
@_cjd_ Thank you for the reply. It will idle at the higher draw indefinitely until I intervene. I had the exact thought you did about the fans running. This just happened again after running a microwakeword training container through the night. I have to stop my other containers that utilize the GPU so I don't max out the available VRAM. Temps obviously rose during that process but even looking in now, fans are running at 0%, GPU is at 48 F and idle state is P8. Still sitting at 19W instead of the usual 10-11W
I'm going to keep updating here in case this helps someone: I was just able to resolve the issue by inputting "nvidia-smi -pm 1" into the command line and rebooting. The command doesn't appear to have an effect before the reboot. I am going to script this as outlined here: https://forums.unraid.net/topic/104151-nvidia-gpu-wont-sleep-p8-after-69-upgrade/ and see if it stabilizes the idle power draw
Edited by obowan
nvidia-smi -pm 1 was deprecated several years ago. The preferred way is to use nvidia-persistenced. I have it in a bash script that runs at array startup.
  • 4 weeks later...
Thank you. I was unaware of this and will change my script.
Continuing to document this issue: reboots don’t always resolve the higher idle. More recently, I disabled auto start for any container that uses the GPU, rebooted and observed the lower idle rate. Starting my containers after the array fully started caused the GPU to idle at the lower state. Something else I’ve noticed is certain containers may affect this. I’m running llama swap, faster-whisper and kokoro with GPU acceleration and they don’t seem to affect the lower idle. When I shut them down and run comfyUI, the GPU idles higher after shutting down comfy, even with no containers using the GPU. Not sure how I can resolve that. Will do if I figure it out
