October 11Oct 11 Intel i3-14100 with 32g of ram.I installed Immich using Compose Manager Plus, got it all installed and working, was able to add photos, search and all. So since the basics were working, I wanted to see what capabilities, if any, I had with my measly integrated gpu.Below is the compse and env files. I added the Intel iGPU part the env, and then I made some edits to the compose file. Since everything was working, and the only changes I made were tot he machine learning section, I know my issues most likely there. I stopped messing with after a bit and decided to come here and see how to fix it. The system has 32Gb of ram, so I'm hoping that can help make up for the paltry gpu.This may be a fool's errand, but I had to at least try as a discreet gpu just isn't going to happen for a long time. If it is truly fruitless, then I could use help just putting the machine learning section back to the defaults.# # WARNING: To install Immich, follow our guide: https://docs.immich.app/install/docker-compose # # Make sure to use the docker-compose.yml of the current release: # # https://github.com/immich-app/immich/releases/latest/download/docker-compose.yml # # The compose file on main may not be compatible with the latest release. name: immich services: immich-server: container_name: immich_server image: ghcr.io/immich-app/immich-server:${IMMICH_VERSION:-release} # extends: # file: hwaccel.transcoding.yml # service: cpu # set to one of [nvenc, quicksync, rkmpp, vaapi, vaapi-wsl] for accelerated transcoding volumes: # Do not edit the next line. If you want to change the media storage location on your system, edit the value of UPLOAD_LOCATION in the .env file - ${UPLOAD_LOCATION}:/data - /etc/localtime:/etc/localtime:ro env_file: - .env ports: - '2283:2283' depends_on: - redis - database restart: always healthcheck: disable: false immich-machine-learning: container_name: immich_machine_learning # For hardware acceleration, add one of -[armnn, cuda, rocm, openvino, rknn] to the image tag. # Example tag: ${IMMICH_VERSION:-release}-cuda image: ghcr.io/immich-app/immich-machine-learning:${IMMICH_VERSION:-release}-openvino # extends: # uncomment this section for hardware acceleration - see https://docs.immich.app/features/ml-hardware-acceleration file: hwaccel.ml.yml # service: cpu # set to one of [armnn, cuda, rocm, openvino, openvino-wsl, rknn] for accelerated inference - use the -wsl version for WSL2 where applicable deploy: resources: reservations: devices: - driver: openvino count: 1 capabilities: - gpu volumes: - model-cache:/cache env_file: - .env restart: always healthcheck: disable: false redis: container_name: immich_redis image: docker.io/valkey/valkey:9@sha256:c123e3715db63d06d4ad6964884037aa0d5d4d703939b9929954112889708e1d healthcheck: test: redis-cli ping | grep -q PONG || exit 1 restart: always database: container_name: immich_postgres image: ghcr.io/immich-app/postgres:14-vectorchord0.4.3-pgvectors0.2.0@sha256:bcf63357191b76a916ae5eb93464d65c07511da41e3bf7a8416db519b40b1c23 environment: POSTGRES_PASSWORD: ${DB_PASSWORD} POSTGRES_USER: ${DB_USERNAME} POSTGRES_DB: ${DB_DATABASE_NAME} POSTGRES_INITDB_ARGS: '--data-checksums' # Uncomment the DB_STORAGE_TYPE: 'HDD' var if your database isn't stored on SSDs # DB_STORAGE_TYPE: 'HDD' volumes: # Do not edit the next line. If you want to change the database storage location on your system, edit the value of DB_DATA_LOCATION in the .env file - ${DB_DATA_LOCATION}:/var/lib/postgresql/data shm_size: 128mb restart: always healthcheck: disable: false volumes: model-cache:# You can find documentation for all the supported env variables at https://docs.immich.app/install/environment-variables # The location where your uploaded files are stored UPLOAD_LOCATION=/mnt/user/Personal_Stuff/Immich # The location where your database files are stored. Network shares are not supported for the database DB_DATA_LOCATION=/mnt/user/appdata/postgresql/data # To set a timezone, uncomment the next line and change Etc/UTC to a TZ identifier from this list: https://en.wikipedia.org/wiki/List_of_tz_database_time_zones#List TZ=America/Chicago # The Immich version to use. You can pin this to a specific version like "v2.1.0" IMMICH_VERSION=v3 # Connection secret for postgres. You should change it to a random password # Please use only the characters A-Za-z0-9, without special characters or spaces DB_PASSWORD=postgres # Intel iGPU device=/dev/dri # The values below this line do not need to be changed ################################################################################### DB_USERNAME=postgres DB_DATABASE_NAME=immich
October 12Oct 12 Community Expert Solution This is what I currently have deployed and it works with my Intel gpu. immich-machine-learning: container_name: immich_machine_learning image: ghcr.io/immich-app/immich-machine-learning:${IMMICH_VERSION:-release}-openvino device_cgroup_rules: - 'c 189:* rmw' devices: - /dev/dri:/dev/dri networks: - proxy-net environment: - PUID=99 - PGID=100 - TZ=${TZ} volumes: - ${ML_CACHE_LOCATION}:/cache env_file: - .env restart: always healthcheck: disable: false
