December 20, 200817 yr BTW, when unRAID reports that its parity-checking rate is X MB/s, the system actually transfers #drives times X MB/s off of the hard disks. With 15 drives and a reported parity-checking rate of 14 MB/s that's 210 MB/s of reads. Additionally, the system writes as much as X MB/s onto the parity drive, in case there are problems.
December 31, 200817 yr Did not post my syslog before... According to this syslog, the system was booted on December 12 at 1pm? The last log entry is on Dec 13. I just mention this in case it is not the syslog you intended to attach. You have not turned on the new NTP feature, so perhaps the unRAID server date and time are wrong? Your system looks fine, with 6 drives on the onboard controller, 4 on each TX4, and 1 on the JMB, and all appear to be optimally configured. The only issue is that the parity drive is on one of the TX4's, on the PCI bus, so I wouldn't expect very good performance. 14MB/s sounds too slow though, even for this setup with multiple full TX4's, but there is no apparent reason for it, in this syslog. There is no parity check covered in this syslog, so I can't say anything about errors then, that may occur behind the scenes during it. Although you reported no difference, I honestly think you should see an improvement, by moving the parity drive to one of the 6 motherboard ports, or a JMB port. Could you post another syslog, with the parity drive moved, and after a parity check? We can check for any errors that may be affecting performance. Sometimes a failing drive can slow everything way down. You might check SMART reports for all of the drives. The SMART View in the MyMain plugin of UnMENU makes it very easy to check SMART status for all drives. One thing to remember, ignore the parity check speed for the first 3 to 5 percent, it actually takes quite a while before it becomes accurate. I've often seen ridiculously low numbers at first, before it rose to over 65MB/s, and slowly decreased, until it finished with a true overall average of 51MB/s, on my all SATA system.
January 6, 200917 yr Thanks for all replies. Will do another parity check and post a new syslog this weekend. I should do the parity check and then directly get the syslog right? Used unmenu with myMain to watch the smart status of my drives. One drive in particular seems to be a bit under the weather. Will this decrease the speed? Time to change it? www.earselect.se/smart.gif
January 6, 200917 yr Both drives sdp and sdn look 'troubled'. You should click the sm link at the far right of each MyMain drive line, to produce a SMART report for each of those drives. Save these reports, so you can compare them later for changes, especially the SMART attributes colored red. You might check these SMART reports for how long ago the errors occurred. Post them here if you aren't sure how to read or interpret them. Drive errors can really affect drive performance, and the errors should show up in the syslog. For more info about SMART, including attributes, commands, testing, discussions etc, see the UnRAID Topical Index, SMART section.
January 6, 200917 yr Thanks for fast reply! never heard of the ata_error_count attribute www.earselect.se/sdp.txt www.earselect.se/sdn.txt I guess I play it safe and order two new ones
January 6, 200917 yr never heard of the ata_error_count attribute That is probably a 'translation' of this in the SMART report: ATA Error Count: 42 I would not give up too quickly on these 2 drives. Now that we can see their SMART reports, it looks to me as if the few problems they display are not recent. I would definitely keep an eye on them. In fact, it would be good to run a SMART long test on each, then get and compare the SMART report with your current report for each. If no surprises, then they should be good for awhile. See this for the SMART long test command. If you are still getting too slow performance, then you should check the syslog for errors during the slow operation.
January 6, 200917 yr Author Sorry it took so long to update, but here's my final report: After adding the cache drive, I'm getting sustained write speeds of over 35MB/second. So, in the end, my reads are over 60MB/second and my writes are over 35MB/second. I am VERY happy. Thanks to all who pitched in.
