November 10, 200620 yr anybody try these? http://www.newegg.com/Product/Product.asp?Item=N82E16817994034 they look pretty cool.
November 15, 200620 yr That exact product you linked to is the tray ONLY. The tray with accompanying housing is this: http://www.newegg.com/Product/Product.asp?Item=N82E16817994023 Probably better off going with their "newly styled" version: http://www.newegg.com/Product/Product.asp?Item=N82E16817994017
November 15, 200620 yr Author That exact product you linked to is the tray ONLY. The tray with accompanying housing is this: http://www.newegg.com/Product/Product.asp?Item=N82E16817994023 Probably better off going with their "newly styled" version: http://www.newegg.com/Product/Product.asp?Item=N82E16817994017 thanks for the correction. so the ones with the lcd display are no good? and wha about the newly styles ones vs the old style ones?
