May 29, 201412 yr I'm running IronicBadger's ArchVM, and have SABnzbd and SickBeard installed. Since the day I installed these programs, about a month ago, I've never had SABnzbd run without experiencing various permissions issues. If I just let SAB run, without having it visible in any tab in a browser, it runs for days without problems, but as soon as I look at it for more than a couple minutes, it starts reporting problems with being unable to access folders and/or files. I've replied to and started several threads looking for resolution, and have gotten lots of responses, but it's all been rather hit and miss, and nothing has led to a full resolution, so I decided to create another thread to try to get this resolved once and for all. Here are the issues, and where I am right now. First issue, and possibly the root of all other issues (not sure), is that I am unable to modify the configuration of SABnzbd file locations, and have those changes stick. * I've just spent some more time investigating this, and it seems that if I select a folder that SAB does not have 'correct' permissions to write to, it will not save that folder in the options. I tried changing it to some random folder, just to see what would happen, and it did save fine, but gave a warning. 2014-05-28 21:13:09,599 ERROR: Cannot change permissions of /mnt/backup/newsgroups I'm not sure why it wanted to change permissions of that folder, nor am I sure why it could not. However, it did at least save this change in the options, which it was not doing before. The permissions for that folder are included here... [root@IronicsArchVM_v4 download]# cd /mnt/backup [root@IronicsArchVM_v4 backup]# ls -l total 4096 drwxrwxrwx 2 nobody users 0 Oct 29 2012 Amazon drwxrwxrwx 2 nobody users 0 Jan 16 17:24 Chris -rwxrwxrwx 1 nobody users 1852 Jun 14 2012 chris Firefox Recovery Key.html -rwxrwxrwx 1 nobody users 389530 Dec 20 2010 Chris old bookmarks.html drwxrwxrwx 2 nobody users 0 May 26 02:27 Drivers -rwxrwxrwx 1 nobody users 95 Oct 30 2013 GARMIN CODES.unl drwxrwxrwx 2 nobody users 0 May 26 02:16 HTPC Tools drwxrwxrwx 2 nobody users 0 May 28 20:00 JRMC drwxrwxrwx 2 nobody users 0 Aug 1 2013 Myrna drwxrwxrwx 2 nobody users 0 Apr 30 15:45 newsgroups drwxrwxrwx 2 nobody users 0 May 27 17:38 nzb drwxrwxrwx 2 nobody users 0 Jan 2 02:32 OpenStreetMaps drwxrwxrwx 2 nobody users 0 Oct 29 2013 Outlook drwxrwxrwx 2 nobody users 0 May 14 02:52 Phone Tools drwxrwxrwx 2 nobody users 0 May 27 02:15 Programs drwxrwxrwx 2 nobody users 0 May 3 02:16 Quicken drwxrwxrwx 2 nobody users 0 Oct 4 2012 Rosetta Stone drwxrwxrwx 2 nobody users 0 Jan 30 20:27 Router drwxrwxrwx 2 nobody users 0 May 27 02:15 unRAID -rwxrwxrwx 1 nobody users 62 Oct 31 2012 Windows7HP Product ID.txt Now, if I try changing that to /mnt/download/incomplete, then save, that doesn't stick. It goes back to /mnt/backup/newsgroups the next time I go into the settings/folder tab. It also gives this error in the "Latest Warnings" area... 2014-05-28 21:27:40,240 ERROR: download_dir directory: /mnt/download/incomplete error accessing permissions for this folder are... [root@IronicsArchVM_v4 download]# cd /mnt/download [root@IronicsArchVM_v4 download]# ls -l total 4 drwxr-xr-x 2 root root 4096 May 28 21:17 incomplete I assumed the problem is that the folder has root:root permissions, so I did this... [root@IronicsArchVM_v4 download]# chown -R nobody:users . [root@IronicsArchVM_v4 download]# ls -l total 4 drwxr-xr-x 2 nobody users 4096 May 28 21:17 incomplete but that didn't help, so then I did a chmod -R 777 *, and got this... [root@IronicsArchVM_v4 download]# chmod -R 777 * [root@IronicsArchVM_v4 download]# ls -l total 4 drwxrwxrwx 2 nobody users 4096 May 28 21:17 incomplete That also did not fix this issue. I still cannot change the temp download directory to /mnt/download/incomplete. I've been messing around with this for so long, and have tried so many things, I suspect I've jacked it up beyond repair at this point, and am considering just creating a new ArchVM from scratch to see if that resolves all these stupid issues. With that said, I don't know what I did to get these problems in the first place. It never worked right, I've had permissions issues since the day I started on this process. Can anyone tell me what permissions should be, on which folders, and which files, and what settings need to be changed from stock to just get a simple SAB setup working as it should? I can provide MUCH more information as far as what I have in my fstab and permissions on various files and folders, but this thread has already grown too long. I REALLY, REALLY appreciate any help anyone can provide to get this resolved.
May 31, 201412 yr Author I created a new ArchVM, from scratch. I fully updated it with pacman -Syyu, then I installed sabnzbd. I updated the sabnzbd.ini file with the minimum changes to get it running. Then I changed the download folder locations, and setup a rule to move music files to a specific folder, then downloaded a nzb and tested. I got 3 errors, all related to permissions. What does one need to do to get sab working without these errors? When Type Warning 2014-05-31 01:10:45,285 ERROR: Post Processing Failed for nzb_d2632d17dce49de8c728056c66bc581c (Cannot create final folder /mnt/music/newsgroup/nzb_d2632d17dce49de8c728056c66bc581c) 2014-05-31 01:10:45,284 ERROR: Failed making (/mnt/music/newsgroup/nzb_d2632d17dce49de8c728056c66bc581c) 2014-05-31 01:06:44,019 ERROR: Error removing /mnt/backup/nzb/nzb_d2632d17dce49de8c728056c66bc581c.nzb Here are the permissions of all my mounts. The backup folder is where I put the nzb watched folder and the download folder is where I put the incomplete downloads... [root@IronicsArchVM_v5 ~]# cd /mnt [root@IronicsArchVM_v5 mnt]# ls -l total 4 drwxr-xr-x 2 root root 0 May 30 13:33 adult drwxr-xr-x 2 nobody users 0 May 31 01:06 backup drwxr-xr-x 2 root root 0 May 30 13:33 documents drwxr-xr-x 2 nobody users 0 May 27 15:14 download drwxr-xr-x 2 root root 0 May 30 13:33 music drwxr-xr-x 2 root root 0 May 30 13:33 photos drwxr-xr-x 2 root root 4096 Feb 4 14:54 tmp drwxr-xr-x 2 root root 0 May 30 13:33 video and here is my fstab... # # /etc/fstab: static file system information # # <file system> <dir> <type> <options> <dump> <pass> # /dev/xvda1 UUID=93ec2c22-36c1-487c-a888-adde602a16fe / ext4 rw,relatime,data=ordered 0 1 //media/adult /mnt/adult cifs auto,x-systemd.automount,guest,noperm,noserverino,uid=nobody,gid=users 0 0 //media/backup /mnt/backup cifs auto,x-systemd.automount,guest,noperm,noserverino,uid=nobody,gid=users 0 0 //media/documents /mnt/documents cifs auto,x-systemd.automount,guest,noperm,noserverino,uid=nobody,gid=users 0 0 //media/download /mnt/download cifs auto,x-systemd.automount,guest,noperm,noserverino,uid=nobody,gid=users 0 0 //media/music /mnt/music cifs auto,x-systemd.automount,guest,noperm,noserverino,uid=nobody,gid=users 0 0 //media/photos /mnt/photos cifs auto,x-systemd.automount,guest,noperm,noserverino,uid=nobody,gid=users 0 0 //media/video /mnt/video cifs auto,x-systemd.automount,guest,noperm,noserverino,uid=nobody,gid=users 0 0
May 31, 201412 yr Author so, I changed my fstab folder to this... # # /etc/fstab: static file system information # # <file system> <dir> <type> <options> <dump> <pass> # /dev/xvda1 UUID=93ec2c22-36c1-487c-a888-adde602a16fe / ext4 rw,relatime,data=ordered 0 1 //media/adult /mnt/adult cifs auto,x-systemd.automount,guest,noperm,noserverino,uid=nobody,gid=users,file_mode=0777,dir_mode=0777,noperm 0 0 //media/backup /mnt/backup cifs auto,x-systemd.automount,guest,noperm,noserverino,uid=nobody,gid=users,file_mode=0777,dir_mode=0777,noperm 0 0 //media/documents /mnt/documents cifs auto,x-systemd.automount,guest,noperm,noserverino,uid=nobody,gid=users,file_mode=0777,dir_mode=0777,noperm 0 0 //media/download /mnt/download cifs auto,x-systemd.automount,guest,noperm,noserverino,uid=nobody,gid=users,file_mode=0777,dir_mode=0777,noperm 0 0 //media/music /mnt/music cifs auto,x-systemd.automount,guest,noperm,noserverino,uid=nobody,gid=users,file_mode=0777,dir_mode=0777,noperm 0 0 //media/photos /mnt/photos cifs auto,x-systemd.automount,guest,noperm,noserverino,uid=nobody,gid=users,file_mode=0777,dir_mode=0777,noperm 0 0 //media/video /mnt/video cifs auto,x-systemd.automount,guest,noperm,noserverino,uid=nobody,gid=users,file_mode=0777,dir_mode=0777,noperm 0 0 then, I rebooted the VM, then checked folder permissions, and they were all back to root:root... [root@IronicsArchVM_v5 ~]# cd /mnt [root@IronicsArchVM_v5 mnt]# ls -l total 4 drwxr-xr-x 2 root root 0 May 31 01:33 adult drwxr-xr-x 2 root root 0 May 31 01:33 backup drwxr-xr-x 2 root root 0 May 31 01:33 documents drwxr-xr-x 2 root root 0 May 31 01:33 download drwxr-xr-x 2 root root 0 May 31 01:33 music drwxr-xr-x 2 root root 0 May 31 01:33 photos drwxr-xr-x 2 root root 4096 Feb 4 14:54 tmp drwxr-xr-x 2 root root 0 May 31 01:33 video Then I downloaded another nzb, and it also failed... 2014-05-31 01:57:55,500 ERROR: Post Processing Failed for Woodsmith Shop-S07E13-Proper (Cannot create final folder /mnt/video/TV/Archive/Woodsmith Shop-S07E13-Proper) 2014-05-31 01:57:55,500 ERROR: Failed making (/mnt/video/TV/Archive/Woodsmith Shop-S07E13-Proper) I checked folder permissions again, and now I got this... [root@IronicsArchVM_v5 mnt]# ls -l total 4 drwxr-xr-x 2 root root 0 May 31 01:33 adult drwxrwxrwx 2 nobody users 0 May 31 01:39 backup drwxr-xr-x 2 root root 0 May 31 01:33 documents drwxrwxrwx 2 nobody users 0 May 27 15:14 download drwxr-xr-x 2 root root 0 May 31 01:33 music drwxr-xr-x 2 root root 0 May 31 01:33 photos drwxr-xr-x 2 root root 4096 Feb 4 14:54 tmp drwxrwxrwx 2 nobody users 0 May 29 08:43 video Surely somebody has this working. What needs changed to get a working setup? It shouldn't be this hard, should it?
June 3, 201412 yr I initially had some fun with this as well. Some things to look at: These are my mounts within fstab: //192.168.1.50/downloads/ /mnt/downloads cifs rw,guest,noauto,x-systemd.automount,uid=nobody,gid=users,file_mode=0777,dir_mode=0777 0 0 //192.168.1.50/movies/ /mnt/movies cifs rw,guest,noauto,x-systemd.automount,uid=nobody,gid-users,file_mode=0777,dir_mode=0777 0 0 //192.168.1.50/tv/ /mnt/tv cifs rw,guest,noauto,x-systemd.automount,uid=nobody,gid=users,file_mode=0777,dir_mode=0777 0 0 //192.168.1.50/software/ /mnt/software cifs rw,guest,noauto,x-systemd.automount,uid=nobody,gid=users,file_mode=0777,dir_mode=0777 0 0 My permissions for /mnt/: drwxrwxrwx 2 nobody users 0 May 31 06:47 downloads drwxr-xr-x 2 root root 0 Jun 1 07:21 movies drwxr-xr-x 2 root root 4096 May 31 05:55 private drwxr-xr-x 2 root root 0 Jun 1 07:21 software drwxr-xr-x 2 root root 4096 Feb 4 14:54 tmp drwxrwxrwx 2 nobody users 0 Jun 2 07:46 tv I am not sure if the nobody:users is required, and I realize it's likely pretty insecure but the system is not available outside my network so I'm not too concerned. I setup the password for my Dom0 root to be the same as the password for my VM's. Can you confirm that the permissions for your /mnt/download folder are recursive? In other words, all your subfolders have the same permissions as the parent? One of these changes (or a combination of) got SAB writing to my downloads folder.
June 4, 201412 yr Author Well, I think I've gotten this squared away now. I have been using user share based permissions on my server for years, and it has mostly worked okay. I use these because I have users that access my media that don't always read warning messages, & I want to protect my media from bulk deletions. Alas, these permissions just don't work with Virtual Machines. I ended up removing all permissions/restrictions from all of my user shares and now my permissions issues inside the VM's are resolved also. I suppose I could try figuring out how to add more users (to match the VM's) and add these restrictions back into unRAID, but with the changes coming down the pipe in how we create and manage VM's, this feels like it will be a constantly changing situation for awhile, and I just don't have the time to dedicate to this issue now. Hopefully, the boys don't delete all my stuff before I can get this situation locked down again, but for now I'm calling this 'good enough'. Thanks for the feedback/advice.
June 10, 201412 yr The problem may be that that you're mounting the shares as "guest". Here's my fstab from my Ubuntu 14.04 VM from which I run all of nzb/torrent clients: //burns/Music /mnt/user/Music cifs auto,file_mode=0777,dir_mode=0777,credentials=/etc/samba/credentials,_netdev,uid=1000,gid=1000 0 0 //burns/Movies /mnt/user/Movies cifs auto,file_mode=0777,dir_mode=0777,credentials=/etc/samba/credentials,_netdev,uid=1000,gid=1000 0 0 //burns/TV_Shows /mnt/user/TV_Shows cifs auto,file_mode=0777,dir_mode=0777,credentials=/etc/samba/credentials,_netdev,uid=1000,gid=1000 0 0 //burns/Kids_Movies /mnt/user/Kids_Movies auto,cifs file_mode=0777,dir_mode=0777,credentials=/etc/samba/credentials,_netdev,uid=1000,gid=1000 0 0 //burns/Kids_TV /mnt/user/Kids_TV cifs auto,file_mode=0777,dir_mode=0777,credentials=/etc/samba/credentials,_netdev,uid=1000,gid=1000 0 0 //burns/Photos /mnt/user/Photos cifs auto,file_mode=0777,dir_mode=0777,credentials=/etc/samba/credentials,_netdev,uid=1000,gid=1000 0 0 //burns/Videos /mnt/user/Videos cifs auto,file_mode=0777,dir_mode=0777,credentials=/etc/samba/credentials,_netdev,uid=1000,gid=1000 0 0 //burns/Incoming /mnt/user/Incoming cifs auto,file_mode=0777,dir_mode=0777,credentials=/etc/samba/credentials,_netdev,uid=1000,gid=1000 0 0 Where /etc/samba/credentials is a permissions protected file that has the username and password of an authorized read/write user of that share in the following format: username=yourusername password=youpass Might be worth a try.
