Fiznap Posted August 30, 2014 Share Posted August 30, 2014 Hi i have a small problem. i have some folder i would like to password protect. then i set it up that some users have access to those folders and some dont. That is working great when users try to access the folder through network. But here comes my problem when users go through web browser example 192.168.1.200 then they press "shares" then they get a list with the folders. when a user click on a folder that is normal password protected for that user. no window pop up with a user login/passwordm instead they have full access to that folder Am i doing anything wrong under the SMB security settings or do i have to set it up some other place. so they cant access those folders from a web browser Regards Brian Link to comment
RobJ Posted September 1, 2014 Share Posted September 1, 2014 I think you may be seeing a case of this: (from Tom's beta 7 release notes) Known issues in this release ---------------------------- ...[snipped]... - emhttp: any file that is world-readable is accessible via http://Tower/mnt/... (which is to say a file can be made non-accessible by making it non-world-readable). Link to comment
