Help with syslog info
Hi,  I'm pretty new to using UnRAID...first time poster.  Brought a server online at the end of last year, and have been enjoying it ever since.  I'm using version 4.3.3 and been really happy with it.
I recently went to the webserver and noticed that my parity drive recorded 40 errors.  I'm attaching the syslog, but I noticed a slew of errors occurring on June 5th.  I think I was copying a slew of files over to the server from multiple machines that night.  I just wanted some help in trying to understand the syslog a little bit more.  Thanks for any help.
I'm currently running a parity check on the system.
You are doing pretty well in understanding the syslog.  there have been a series of errors when attempting to read the parity drive /dev/sda
You should run a smartctl report on the drive to learn its health and post its output.
smartctl -a -d ata /dev/sda
It could be that you had a series of unreadable sectors on the disk, or it could be a loose/bad cable, or any number of other hardware issues.  Since the errors have not continued there is some hope. (Although it does make it much easier to find and isolate the root cause if the errors were still occurring)
If you get an error message stating a library file is missing when you run the "smartctl" command, see this post on how to install the missing library:
http://lime-technology.com/forum/index.php?topic=2595.msg25343#msg25343
You do not need to wait for the parity check to finish before running the smartctl command.  Post its output for analysis.  You will be looking for reallocated sectors, and sectors pending reallocation.  Both of those indicate the drive;s hardware found problems with a sector and relocated the data on a subsequent "write" to the drive, or is waiting for a subsequent write to reallocate the data.
A parity drive with an unreadable sector will not be able to be used to recover other drives properly if they fail.  A few reallocated sectors is OK, but pending reallocation is not (at least not on a parity drive, as nothing would write to those same sectors unless you deleted and re-loaded the involved sectors somehow.)
If the sectors reallocate, and no more are detected, then you'll probably be fine.  If you see the errors in the smartctl report continuing to increase in count (more sectors needing reallocation), you'll probably want to RMA the drive.
Joe L.
Yeah, this is where I am now starting to get confused.  After I let the server do a parity check, it reported under the "Disk Status" that the parity drive had 1473 errors  :o , yet the check came up with 0 errors.  I did as you suggested Joe with the smartctl command, and the drive reported a bunch of different errors shown below.
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG    VALUE WORST THRESH TYPE      UPDATED  WHEN_
FAILED RAW_VALUE
  1 Raw_Read_Error_Rate    0x000f  115  099  006    Pre-fail  Always      -
      90865157
  3 Spin_Up_Time            0x0003  091  090  000    Pre-fail  Always      -
      0
  4 Start_Stop_Count        0x0032  100  100  020    Old_age  Always      -
      14
  5 Reallocated_Sector_Ct  0x0033  100  100  036    Pre-fail  Always      -
      1
  7 Seek_Error_Rate        0x000f  068  060  030    Pre-fail  Always      -
      6514230
  9 Power_On_Hours          0x0032  096  096  000    Old_age  Always      -
      4062
10 Spin_Retry_Count        0x0013  100  100  097    Pre-fail  Always      -
      1
12 Power_Cycle_Count      0x0032  100  100  020    Old_age  Always      -
      8
184 Unknown_Attribute      0x0032  100  100  099    Old_age  Always      -
      0
187 Unknown_Attribute      0x0032  001  001  000    Old_age  Always      -
      154
188 Unknown_Attribute      0x0032  100  100  000    Old_age  Always      -
      0
189 Unknown_Attribute      0x003a  100  100  000    Old_age  Always      -
      0
190 Unknown_Attribute      0x0022  071  070  045    Old_age  Always      -
      504889373
194 Temperature_Celsius    0x0022  029  040  000    Old_age  Always      -
      29 (Lifetime Min/Max 0/15)
195 Hardware_ECC_Recovered  0x001a  046  016  000    Old_age  Always      -
      90865157
197 Current_Pending_Sector  0x0012  100  100  000    Old_age  Always      -
      0
198 Offline_Uncorrectable  0x0010  100  100  000    Old_age  Offline      -
      0
199 UDMA_CRC_Error_Count    0x003e  200  200  000    Old_age  Always      -
      0
SMART Error Log Version: 1
ATA Error Count: 154 (device log contains only the most recent five errors)
        CR = Command Register [HEX]
        FR = Features Register [HEX]
        SC = Sector Count Register [HEX]
        SN = Sector Number Register [HEX]
        CL = Cylinder Low Register [HEX]
        CH = Cylinder High Register [HEX]
        DH = Device/Head Register [HEX]
        DC = Device Command Register [HEX]
        ER = Error register [HEX]
        ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 154 occurred at disk power-on lifetime: 4052 hours (168 days + 20 hours)
  When the command that caused the error occurred, the device was active or idle
  After command completion occurred, registers were:
  ER ST SC SN CL CH DH
  40 51 00 ff ff ff 0f  Error: UNC at LBA = 0x0fffffff = 268435455
  Commands leading to the command that caused the error were:
  CR FR SC SN CL CH DH DC  Powered_Up_Time  Command/Feature_Name
  25 00 00 ff ff ff ef 00  48d+12:59:25.442  READ DMA EXT
  27 00 00 00 00 00 e0 00  48d+12:59:25.376  READ NATIVE MAX ADDRESS EXT
  ec 00 00 00 00 00 a0 00  48d+12:59:25.356  IDENTIFY DEVICE
  ef 03 46 00 00 00 a0 00  48d+12:59:25.337  SET FEATURES [set transfer mode]
  27 00 00 00 00 00 e0 00  48d+12:59:25.316  READ NATIVE MAX ADDRESS EXT
Error 153 occurred at disk power-on lifetime: 4052 hours (168 days + 20 hours)
  25 00 00 ff ff ff ef 00  48d+12:59:22.361  READ DMA EXT
  27 00 00 00 00 00 e0 00  48d+12:59:22.295  READ NATIVE MAX ADDRESS EXT
  ec 00 00 00 00 00 a0 00  48d+12:59:22.275  IDENTIFY DEVICE
  ef 03 46 00 00 00 a0 00  48d+12:59:22.255  SET FEATURES [set transfer mode]
  27 00 00 00 00 00 e0 00  48d+12:59:22.235  READ NATIVE MAX ADDRESS EXT
Error 152 occurred at disk power-on lifetime: 4052 hours (168 days + 20 hours)
  25 00 00 ff ff ff ef 00  48d+12:59:19.280  READ DMA EXT
  27 00 00 00 00 00 e0 00  48d+12:59:19.214  READ NATIVE MAX ADDRESS EXT
  ec 00 00 00 00 00 a0 00  48d+12:59:19.193  IDENTIFY DEVICE
  ef 03 46 00 00 00 a0 00  48d+12:59:19.174  SET FEATURES [set transfer mode]
  27 00 00 00 00 00 e0 00  48d+12:59:19.153  READ NATIVE MAX ADDRESS EXT
Error 151 occurred at disk power-on lifetime: 4052 hours (168 days + 20 hours)
  25 00 00 ff ff ff ef 00  48d+12:59:16.198  READ DMA EXT
  27 00 00 00 00 00 e0 00  48d+12:59:16.132  READ NATIVE MAX ADDRESS EXT
  ec 00 00 00 00 00 a0 00  48d+12:59:16.112  IDENTIFY DEVICE
  ef 03 46 00 00 00 a0 00  48d+12:59:16.092  SET FEATURES [set transfer mode]
  27 00 00 00 00 00 e0 00  48d+12:59:16.072  READ NATIVE MAX ADDRESS EXT
Error 150 occurred at disk power-on lifetime: 4052 hours (168 days + 20 hours)
  25 00 00 ff ff ff ef 00  48d+12:59:13.137  READ DMA EXT
  27 00 00 00 00 00 e0 00  48d+12:59:13.071  READ NATIVE MAX ADDRESS EXT
  ec 00 00 00 00 00 a0 00  48d+12:59:13.050  IDENTIFY DEVICE
  ef 03 46 00 00 00 a0 00  48d+12:59:13.040  SET FEATURES [set transfer mode]
  27 00 00 00 00 00 e0 00  48d+12:59:12.980  READ NATIVE MAX ADDRESS EXT
SMART Self-test log structure revision number 1
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
I ended up clearing the statistics and did another parity check.  This time I have 0 errors under the "Disk Status", so I don't know what to make of it, and the parity check came back with 0 errors.
I've attached the updated syslog (syslog_130609.txt).  I had to edit it to get the file size down, so I included only today's date.  Also where alot of the errors are repetitive, I've left the beginning bunch and end bunch but took out the errors in between.
Thanks for any more info anyone can provide.  Right now this is a little over my head so it is very much appreciated.
There are two different kinds of "errors" involved in your report..
First are "read" errors associated with a specific disk drive.  Those occur when a request to read a specific disk fails.  When this occurs, from what I understand, unRAID will re-try to read the data.  If un-successful, the data that should have been returned will be re-created by reading the parity disk and all the other data disks.  It will then write the data to the disk it could not read.  If the sector on the disk being read was un-readable, and the disk hardware detected that, it would normally mark the sector pending reallocation.  Before reallocation, on the next "write" to that same sector it would first try to write to the sector it initially could not read and if it could then read back the data, it would not need to do anything more.  If it could not read back the data it would relocate the data elsewhere on the disk as a relocated sector.  Your disk's smart report shows 1 reallocated sector.  you have 0 sectors pending reallocation.  Together those seem to indicate a drive that is in pretty good shape.
The other "RAW" values for Raw_Read_Error_Rate and Hardware_ECC (error correcting code) Recovered Data are only meaningful to the manufacturer.  All disks rely on hardware error correction... it is only when the hardware error correction gets to where it cannot that a drive will fail SMART tests.
You do have other errors listed though... All failures when trying to read data from the drive.  To me, they could easily be an indication of a bad/poor quality cable to the drive.  That would be my first suspect.
The second type of error, "parity errors" occur when the value stored on the parity drive is not as expected based on reading the data drives.  I've only ever had that type of error once on my server, when my power company dropped power to the area in a storm and the parity drive was not written to as I was writing to the array.  You should never see "parity check" errors unless you have a improper shut-down.  You can of course see "read" errors on any drive at any time.  In the same way, you can have "write" errors on any drive at any time, but unRAID will take a drive off-line if a single write to it fails.  You'll see the indicator next to a drive turn red when this occurs. (hopefully, you'll never see this... but alas, given enough time, and enough disk drives, one will fail.)
Oh yes, I'm impressed about one thing... the drive seems to be reporting 169 days of up-time and only 8 power cycles...  Apparently your power company is reliable and do not need to shut the server down very often.
Joe L.
Gees Joe, thanks for the info.  That's a great wealth of information you gave me....thank you.
Curious, what cables would you suggest to use?  Currently I'm using the standard off-the-shelf SATA interface cable....around 18" in length.  Please don't say Monster (if they indeed even sell SATA cable)...I just can't go there  :P .
Thanks again for the excellent info.
FYI, my UnRAID server consists of the following:
Motherboard: ECS 945GCT-M/1333 Socket 775 w/video, and LAN
CPU: Intel Celeron 440
RAM: Kingston ValueRAM 2x512MB KVR667D2N5K2/1G
Cooler: Artic Cooling Alpine 7 Pro
Power Supply: Antec EA-650
Hard Drives: 2x Seagate Barracuda ST3750630AS and 1x Seagate Barracuda ST3500418AS
Planning on upgrading to most likely Pro one day.
Not monster... even if they did make one...  I only have one monster product in my home, and it was a freebe gift... and it is not a cable.
Try monoprice.com  Their prices are very good, and from what I've read in this forum and others, the quality very good.
Check out this link where I searched for sata2 and locking (the locking type tend to not get loose as easily as the non-locking type):
http://www.monoprice.com/products/search.asp?keyword=sata2+locking&x=0&y=0
They are roughly 1.53 in single quantities, or $1.47 for 2 or more...  dropping to $1.42 if you buy 10...
I'd get 10 at that price... (and I'll bet that $14.20 for 10 18" locking cables is about as good a deal as you'll find, you can even choose the color.)
Joe L.
