tr0910 Posted May 16, 2015 Share Posted May 16, 2015 Because of some router issues, I had to power cycle my unRaid b6v14b It came back up with an unclean shutdown as expected, but the XFS cache drive is unmountable. With Reiser we know what to try, but what is the process to try and fix an XFS drive?? The cache drive only contains my dockers. I will move to rc1 once we fix this little issue. Link to comment
tr0910 Posted May 17, 2015 Author Share Posted May 17, 2015 So xfs_repair reports the following. If unRaid 6b15 or 6rc2 both find the drive unmountable, should I mount outside of unRaid to attempt to repair?? Or just destroy the log and move on??? root@SandBox:~# fdisk -l /dev/sdb Disk /dev/sdb: 2000.4 GB, 2000398934016 bytes 1 heads, 32 sectors/track, 122094661 cylinders, total 3907029168 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk identifier: 0x00000000 Device Boot Start End Blocks Id System /dev/sdb1 64 3907029167 1953514552 83 Linux root@SandBox:~# xfs_repair /dev/sdb1 Phase 1 - find and verify superblock... Phase 2 - using internal log - zero log... ERROR: The filesystem has valuable metadata changes in a log which needs to be replayed. Mount the filesystem to replay the log, and unmount it before re-running xfs_repair. If you are unable to mount the filesystem, then use the -L option to destroy the log and attempt a repair. Note that destroying the log may cause corruption -- please attempt a mount of the filesystem before doing this. root@SandBox:~# Link to comment
tr0910 Posted May 18, 2015 Author Share Posted May 18, 2015 So xfs_repair reports the following. If unRaid 6b15 or 6rc2 both find the drive unmountable, should I mount outside of unRaid to attempt to repair?? So how would I mount a cache drive for XFS_Repair that rc2 claims is unmountable?? Link to comment
tr0910 Posted May 19, 2015 Author Share Posted May 19, 2015 So I ran XFS_Repair zeroing the log and got the cache drive back working. All the data seems to be there and there is a lost+found directory with 10 files in it. But now Docker doesn't want to start. I'll create a post over there to see if we can get them back working. Link to comment
