thestewman Posted July 9, 2015 Share Posted July 9, 2015 i am using unRaid OS v6.01 I recently replaced my 4tb WD Red parity drive with a 6tb HGST because my 4tb drives were starting to fill to capacity. I pre-cleared 3 new 6tb drives using the new Preclear plugin and it went perfectly. The change in parity drives went well and a new parity check went without error. Now I have to replace 2 of the 4tb Data drives. In anticipation I copied all the media data from the movies share on drives #1 (sdf) and #2 (sdh) to one of the 6tb drives that is in drive location #11 and now labeled as sdm. My share setup on drives 1 and 2: Name: movies SMB: public NFS: public Allocation: Fillup Min: 40gb Split level: Auto split any directory I did not setup a share on the new drive and placed the media in folders. I need to know how to remove the two old drives. Then how to put the new drives into positions 1 and 2 And then set up the movies share again Thanks in advance Link to comment
