AOC-SASLP-MV8 Firmware Problems
I am currently running 2 AOC-SASLP-MV8 card with firmware 3.1.0.21 with no problems, card are not in RAID mode and I can enter the CNTL+M menu
I am looking to expand and have bought a third AOC-SASLP-MV8 card, second hand. Before installing in my server, I thought I'd just try it out on my main PC
I found that it was running 3.1.015 firmware, and was not showing me the CNTL+M menu.
So I flashed it to 3.1.0.21 like the others, on booting up it did, very briefly show me the CNTL+M menu, but I was not quick enough to select it. Now the card boots up in RAID mode
I have tried rebooting a number times, and the CNTL+M menu is not shown, and the card goes into RAID mode. I have even reflashed the card with 3.0.1.21 firmware a couple of times, but on booting I still do not have the CNTL+M menu and the card is in RAID mode?
The other two cards I did not have to touch the firmware at all, they came with 3.0.1.21 firmware with the RAID option off.
I understand that 3.0.1.15 does not have the RAID option, and considered reflashing the cards to this firmware, but I can't find it listed on Supermicro's website
I would be very grateful for guidance, how do I switch off the RAID mode in 3.0.1.21 firmware?
I should add that there are two different folders whuch you can download with 3.0.1.21 firmware
1) MVF, SMC DOS4GW and 6480,BIN files. This is the version I have run using MVF 6480.BIN to install from DOS
2) MDU, SMC, DOS4GW, 6480.BIN and SNC_N (text file) I have tried running MDU 6480.BIN from DOS but this command is not recognised -
I have noticed the text file SNC_N mentioned that RAID is to be switched off, but I am not sure how to run the commands, text file is as follows:-
#              HBA Configuration.
#  Modify for Supermicro  change SAS address OUI to SMC 00-30-48
#  Modify for Supermicro  set RAID=disable RAID5=disable
[ADAPTER CONFIG]  #adapter config
[bEGIN]
[sERIAL_NUMBER]=VA2400WWXX0000000000
[sUBVENDOR_ID]=15D9
[sUBDEVICE_ID]=0500
[sILENT_MODE]=DISABLE
[iNT13]=ENABLE
[ERROR_STOP]=DISABLE
[RAID FEATURE]=DISABLE
[RAID5]=DISABLE
[sPINUP GROUP]=8
[sPINUP TIME]=0
[DELAY TIME(s)]=5
[END]
[PORT CONFIG]  # port config
[bEGIN]
[PORT ID]=0
[sASADDRESS]=50030480:00000000
[RATE]=3.0G
[AMP]=F
[PRE_EMPHASIS]=7
[DRIVE]=3F
[PRE_HALF]=ENABLE
[PORT ID]=1
[RATE]=3.0G
[AMP]=F
[PRE_EMPHASIS]=7
[DRIVE]=3F
[PRE_HALF]=ENABLE
[PORT ID]=2
[RATE]=3.0G
[AMP]=F
[PRE_EMPHASIS]=7
[DRIVE]=3F
[PRE_HALF]=ENABLE
[PORT ID]=3
[RATE]=3.0G
[AMP]=F
[PRE_EMPHASIS]=7
[DRIVE]=3F
[PRE_HALF]=ENABLE
[PORT ID]=4
[RATE]=3.0G
[AMP]=F
[PRE_EMPHASIS]=7
[DRIVE]=3F
[PRE_HALF]=ENABLE
[PORT ID]=5
[RATE]=3.0G
[AMP]=F
[PRE_EMPHASIS]=7
[DRIVE]=3F
[PRE_HALF]=ENABLE
[PORT ID]=6
[RATE]=3.0G
[AMP]=F
[PRE_EMPHASIS]=7
[DRIVE]=3F
[PRE_HALF]=ENABLE
[PORT ID]=7
[RATE]=3.0G
[AMP]=F
[PRE_EMPHASIS]=7
[DRIVE]=3F
[PRE_HALF]=ENABLE
[END]
[RAID CONFIG] # raid config(include vd and spare disk)
[bEGIN]
[END]
[AUTOLOAD CONFIG]  # AutoLoad data
[bEGIN]
[END]
After a lot of research and mucking about, I have now removed the RAID function from the card
