alex Posted March 5, 2016 Share Posted March 5, 2016 Hey guys, On my config I have two VM and the plex server app running. But one of my VM is a bit unstable. When I try to start it it often stop itself after a few seconds but I usually get it started after a second try. I wonder if it is because I don't have enough HDD (see at the end of the topic). I also tried to passthrough my soundcard to that VM and it dosen't work(it sounds weird). I also tried to passthrough my G930 headset (USB) and I hear nothing I see the soundbar moving in windows sound mixer but no sound. With my headset the button to raise the volume also work I can see the volume raising in windows when I use the button. First VM: Windows server 2012 10 GB of RAM 2TB HDD GPU:VNC Used for ftp and other custom apps SecondVM: Windows 10 10GB RAM 500GB HDD GPU:GTX780 passthrough Used for gaming and media I was planing to have one more VM but not until the first two get stable. A small one with windows 8.1 4 gb of ram 20GB of HDD and VNC My config. I7 4930k @4.5ghz 32 GB of ram @ 2400 mhz G.SKILL Ripjaws GPU1:HD4770<- unRAID GPU2:GTX780<- Gaming VM HHDs: Cache: 1XSamsung PRO SSD 512GB<- plex server app Array: 1xWD 4GB I think it's a blue<- NAS shares (some use cache) and windows server 2012 1X 750GB HDD seagate SATAIII <- Gaming VM So is my setup enough to do what I wan't to do? Thanks Alex Link to comment
alex Posted March 6, 2016 Author Share Posted March 6, 2016 I found out what is making my VM unstable. It's my mouse. It's a razer mamba but I don't understand why it makes my VM crash... Link to comment
jrhumphrey89 Posted March 30, 2016 Share Posted March 30, 2016 Did you install the razer drivers? Link to comment
yesdog Posted March 30, 2016 Share Posted March 30, 2016 I would double check the drivers and also the MSI interrupt config for the devices. Choppy sound, poor UI performance, overall instability, device activity adding to instability- usually a good cause of this is mismanaged interrupts, and having MSI disabled will cause windows to handle alll devices poorly because the GPU is choking them out. Link to comment
