Power Flicker killed drive?
My UPS battery died this weekend and we hadn't had a power outage in 7 months so of course when I plugged in my server without the UPS so I could use it over the weekend before my new batteries arrived the power flickers just enough to reboot my server.  Now my newest drive (6 months WD red 3TB) has a red X.  Ran Smart reports (long version) came back clean so I decided to try rebuilding the drive.  27 hours later the message said Data Rebuild completed with 0 errors and then the next entry is "Disk 5 in error state (disk dsbl)"
attaching the last test I have. Currently running a new long test.  Is this drive likely dead?
tower-smart-20160621-2146.zip
There are no pending sectors but from the SMART errors logged it does look look a bad disk, only last 5 errors are shown:
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG    VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate    0x002f  200  200  051    Pre-fail  Always      -      0
  3 Spin_Up_Time            0x0027  231  185  021    Pre-fail  Always      -      3441
  4 Start_Stop_Count        0x0032  100  100  000    Old_age  Always      -      56
  5 Reallocated_Sector_Ct  0x0033  200  200  140    Pre-fail  Always      -      0
  7 Seek_Error_Rate        0x002e  200  200  000    Old_age  Always      -      0
  9 Power_On_Hours          0x0032  095  095  000    Old_age  Always      -      4209
10 Spin_Retry_Count        0x0032  100  253  000    Old_age  Always      -      0
11 Calibration_Retry_Count 0x0032  100  253  000    Old_age  Always      -      0
12 Power_Cycle_Count      0x0032  100  100  000    Old_age  Always      -      56
192 Power-Off_Retract_Count 0x0032  200  200  000    Old_age  Always      -      43
193 Load_Cycle_Count        0x0032  199  199  000    Old_age  Always      -      5288
194 Temperature_Celsius    0x0022  114  109  000    Old_age  Always      -      36
196 Reallocated_Event_Count 0x0032  200  200  000    Old_age  Always      -      0
197 Current_Pending_Sector  0x0032  200  200  000    Old_age  Always      -      0
198 Offline_Uncorrectable  0x0030  100  253  000    Old_age  Offline      -      0
199 UDMA_CRC_Error_Count    0x0032  200  200  000    Old_age  Always      -      0
200 Multi_Zone_Error_Rate  0x0008  200  200  000    Old_age  Offline      -      0
SMART Error Log Version: 1
ATA Error Count: 96 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 96 occurred at disk power-on lifetime: 4162 hours (173 days + 10 hours)
  When the command that caused the error occurred, the device was active or idle.
  After command completion occurred, registers were:
  ER ST SC SN CL CH DH
  04 61 02 00 00 00 a0  Device Fault; Error: ABRT
  Commands leading to the command that caused the error were:
  CR FR SC SN CL CH DH DC  Powered_Up_Time  Command/Feature_Name
  ef 10 02 00 00 00 a0 08      00:10:45.713  SET FEATURES [Enable SATA feature]
  ec 00 00 00 00 00 a0 08      00:10:45.712  IDENTIFY DEVICE
  ef 03 45 00 00 00 a0 08      00:10:45.712  SET FEATURES [set transfer mode]
  ef 10 02 00 00 00 a0 08      00:10:45.712  SET FEATURES [Enable SATA feature]
  ec 00 00 00 00 00 a0 08      00:10:45.711  IDENTIFY DEVICE
Error 95 occurred at disk power-on lifetime: 4162 hours (173 days + 10 hours)
  04 61 45 00 00 00 a0  Device Fault; Error: ABRT
  ef 10 02 00 00 00 a0 08      00:10:40.258  SET FEATURES [Enable SATA feature]
  ec 00 00 00 00 00 a0 08      00:10:40.258  IDENTIFY DEVICE
Error 94 occurred at disk power-on lifetime: 4162 hours (173 days + 10 hours)
  ef 03 45 00 00 00 a0 08      00:10:40.257  SET FEATURES [set transfer mode]
Error 93 occurred at disk power-on lifetime: 4162 hours (173 days + 10 hours)
  ef 10 02 00 00 00 a0 08      00:10:40.257  SET FEATURES [Enable SATA feature]
Error 92 occurred at disk power-on lifetime: 4162 hours (173 days + 10 hours)
  ec 00 00 00 00 00 a0 08      00:10:40.256  IDENTIFY DEVICE
  ec 00 00 00 00 00 a0 08      00:10:21.095  IDENTIFY DEVICE
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Extended offline    Completed without error      00%      4169        -
# 2  Short offline      Completed without error      00%      4162        -
# 3  Extended offline    Completed without error      00%      1867        -
SMART Selective self-test log data structure revision number 1
SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Finished a new Long Test overnight.  Haven't had a chance to see if it has anything new but wanted to post this before I left for work.
tower-smart-20160621-2155.zip
Extended SMART test completed without error, still believe that this disk is not very healthy, you could try using it on another server (if you have one) or in the same server but trading cables and controller/enclosure with another disk, if the same disk fails again in the future then you can be sure it's bad.
I paid the taxes to buy a new disc locally to replace this one with the intent of running a pre-clear on it after I get the new one pre-cleared and rebuilt.  If that comes back with issues I will start the warranty process.  If not I, I do have a pro license and I'm only currently at 9 disk so I can try it.
Thanks for the help so far.
Just my opinion, but I think the drive is fine.  All of the visible errors are just device faults from 47 hours ago, rather unusual, but probably just issues with the bad power incident.  There's no other evidence of anything physically wrong with the drive.  And the faults haven't occurred since, so probably the drive was fine once rebooted.
The issue is that after two reboots and a rebuild I still can't get unraid to not report it as faulty and enable it.
So the drive is unmountable?
Rebuilding an unmountable drive won't make it mountable if e.g. there's a file system corruption. Wait for one of our experts to tell you what to do next.
So the rebuild completed successfully but the disk was disabled right after?
If you still have it post the syslog that includes the rebuild.
I bought a new drive and pre-cleared it and rebuilt Drive 5 on the new drive.  I then Pre-cleared the offending drive with full test and it completed with no errors.  I ran the SMART Short test which came back without errors.  Before I start a SMART extended test is there anything else I should do to check this drive so I can feel comfortable adding it back in?
By the way thanks again to everyone for the help.
Didn't see your post in time but I imagine pre clearing a drive and adding it in as a new drive would probably take care of this issue, correct?
