December 1, 20169 yr I noticed this problem in 6.2 and in 6.3 the problem has gotten worst. In 6.2 when I reboot my server I was not able to access the web interface till all dockers and my VM finished loading, in the latest version it's the same problem but now it take about 30 minutes after everything is loaded before I can access the web interface. Access Unraid via latest version of Firefox. unraid-diagnostics-20161201-1725.zip
December 7, 20169 yr I noticed this problem in 6.2 and in 6.3 the problem has gotten worst. In 6.2 when I reboot my server I was not able to access the web interface till all dockers and my VM finished loading, in the latest version it's the same problem but now it take about 30 minutes after everything is loaded before I can access the web interface. Access Unraid via latest version of Firefox. Looks like something is odd between your unRAID machine and DNS server (192.168.1.25). For example, when unRAID is trying to check for Docker updates it attempts to connect to the local machine (127.0.0.1) instead of Docker's index and registry servers. As a test, remove 192.168.1.25 and 192.168.1.1 from your DNS settings and just set DNS1 to 8.8.8.8, then see how fast the web interface loads after a reboot. Anything beyond a 1min is abnormal.
December 8, 20169 yr Author Seems to behaving now after removing the local DNS server, still testing as I get time to bring down the server. Thank you.
