Let me know if problem with my chosen parts list
So, I decided that in order to circumvent the expected massive failure of my hardware (my current build is about 10 years old), I'm just going to upgrade a bunch of stuff at once.  I have the Cooler Master Centurion case and I'm going to re-use that.  I'm replacing my CPU, Mobo, RAM and power supply.  Also buying a HotSwap drive bay, as I don't want to mess with the hassle of taking everything apart in order to replace drives/etc.  My array is currently 4 disks, 1 parity and 3 X 3TB drives and I don't foresee needing any more disks (I have about 5TB of stuff and I figure that drives are getting bigger faster than my need for storage)  So, if anyone could let me know if they see a problem with any of my components, let me know...
CPU
Intel Core i3-7100 7th Gen Core Desktop Processor 3M Cache,3.90 GHz (BX80677I37100) $119
https://www.amazon.com/gp/product/B01NCESRJX/ref=ox_sc_act_title_2?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
MOBO
MSI Pro Series Intel B250 LGA 1151 DDR4 HDMI USB 3.1 ATX Motherboard (B250 PC MATE) $89.90
https://www.amazon.com/gp/product/B01N4LCX2D/ref=ox_sc_act_title_3?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
RAM
Ballistix Sport LT 8GB Kit (4GBx2) DDR4 2400 MT/s (PC4-19200) DIMM 288-Pin - BLS2K4G4D240FSE (Red) $60
https://www.amazon.com/gp/product/B01F4Z4OPW/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
Power Supply
EVGA 500 W1, 80+ WHITE 500W Power Supply( 100-W1-0500-KR) $40
https://www.amazon.com/gp/product/B00H33SFJU/ref=ox_sc_act_title_4?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
Hot Swap Drive Bay
ICY DOCK Black Vortex MB074SP-1B 4 Bay 3.5" SATA Hard Drive Backplane Cooler Cage with 120mm Front LED Fan in 3x 5.25" Bay $70
https://www.amazon.com/gp/product/B00LICRE8A/ref=ox_sc_act_title_5?ie=UTF8&psc=1&smid=A1GQQIQD0YQTUY
Thanks in advance for any help!
Chris
Looks good from the specs, though I have not used that motherboard.  Is it safe to assume that your use case is NAS plus perhaps a few Dockers?
@tdallen Thanks.  Yes, NAS plus I'm going to start looking at setting up some Dockers.  I'm probably overkill on RAM and CPU if I just decide to stick with using it as a NAS.  As far as the hardware goes, I can afford to spend a few bucks on 'reliability'.  I've got three little kids and just don't have the time to tinker, so I kinda want to just set this up and forget about it for the next 3-4 years.
I don't consider 8GB overkill, the Core i3 maybe just a little but in a good way :).  If you ever get into Plex you'll need it.  Speaking of which, you'll want an SSD for a cache drive, which is the de facto "application" drive in unRAID 6+.  From a hardware perspective you should be good for a while, but the pace of software updates has been quite frequent recently so you'll want to keep up there.
Consider the new G46xx Pentiums - they've got 2 cores with Hyperthreading, so are basically an i3 only cheaper.
