June 14, 20179 yr Hi, I am running a big website at a hoster. On my old server (which should be replaced by unraid) I am using curlftpfs to mount the ftp directory and then doing a rsync on changes. It seems that curlftpfs is not available on unraid. Does someone have an Idea how I can do this backup on unraid? I have only HTTP and FTP Access to my Website. No SSH. Br, Johannes
June 14, 20179 yr Author Hi, It seems I found an option via lftp and the mirror option. Testing now the following script: #!/bin/sh # @author: Alexandre Plennevaux # @description: MIRROR DISTANT FOLDER TO LOCAL FOLDER VIA FTP # # FTP LOGIN HOST='sftp://ftp.domain.com' USER='ftpusername' PASSWORD='ftppassword' # DISTANT DIRECTORY REMOTE_DIR='/absolute/path/to/remote/directory' #LOCAL DIRECTORY LOCAL_DIR='/absolute/path/to/local/directory' # RUNTIME! echo echo "Starting download $REMOTE_DIR from $HOST to $LOCAL_DIR" date lftp -u "$USER","$PASSWORD" $HOST <<EOF # the next 3 lines put you in ftpes mode. Uncomment if you are having trouble connecting. # set ftp:ssl-force true # set ftp:ssl-protect-data true # set ssl:verify-certificate no # transfer starts now... mirror --use-pget-n=10 $REMOTE_DIR $LOCAL_DIR; exit EOF echo echo "Transfer finished" date
