December 7, 20187 yr Ok I just fixed my entire UnRAID by upgrading all the drives to xfs and the cache to btrfs. I only have one cache right now until my two SSD show up. I was resetting all the things I turned off while moving data which was the Scheduler. Once I turned it on I got a new error I never seen before. I researched the forum but could not find a match for this error which was under Mover Schedule "Cache disk not enabled!" I checked to make sure the Cache disk was enabled and it was so I have not clue what it is referring too. I attached a pic of it. Any help is very much appreciated. Thanks
December 8, 20187 yr Author Sorry it took awhile I had a CPU die so had to switch out motherboards... rocking with better one now. mistymtnmedia-diagnostics-20181208-0108.zip
July 7, 20197 yr Author On 12/7/2018 at 2:21 PM, Squid said: Tools - Diagnostics - Post entire zip Squid I am still having this Cache Drive not enable error. I am reposting my diag file for some help. Thanks mistymtnmedia-diagnostics-20190707-1708.zip
July 7, 20197 yr Author 1 hour ago, Squid said: Squid you beat me to it, I had a Duh moment. I caught it right before you posted.. Thanks again..
