After power outage - Sporadic Unraid network disconnects, dockers lose paths, various network problems
Issues:
  • Unraid randomly disconnects from the network for 5-15 seconds every 10min - 1h.
  • Constant Plex problems (ethernet connection from server to plex player)
    • Local videos being played as remote instead of local
    • Videos end early and skip
    • The actual "remote access" enables and disables randomly
  • After a disconnect, I lose all jackett functionally through radarr/sonarr and radarr/sonnar can't see my files until I restart the server
Attempted Troubleshooting:
  • Full network restart (modem, router, switch)
  • Multiple "Fix Common Problems" tests ran without any errors
  • Permission repair
  • Replaced network switch
  • I thought my IP might be changing, so I disabled all IPv6 in router settings
  • Disabled dockers individually
A couple weeks back, my server had a day long power outage while I was out of town. The UPS I had connected (which has since then been replaced) didn't have any Sine wave technology, so the server did a hard shut down. When I got home, I booted it up, did a parity check (resulting in no errors), and since then I've had this list of problems.
The only odd things popping up in my log are errors showing "Possible SYN flooding on port xxxx". It usually doesn't at the same times as the disconnects, the port isn't consistent, and its never a port thats affiliated with any of the dockers or VM's (I just assume it has to do with my torrent traffic).
Unfortunately, I attempted my own troubleshooting of the issue with restarts and such before pulling the unclean shutdown log like I should have.
Edited by Kudagra
I’d highly recommend posting up your Diagnostics file.
Will do. Is there any sensitive data in the Diagnostics that I should remove/sensor before uploading?
Edited by Kudagra
2 hours ago, Kudagra said:
Will do. Is there any sensitive data in the Diagnostics that I should remove/sensor before uploaiding?
No the Diagnostic script doesn’t really show any sensitive data.
You can look look at others that have posted theirs if you would like to see what it does for a little reassurance.
