Dual CPU Temps + Technical Help Req.
First question is how can we display temperatures of a dual-CPU system along with a motherboard, and other system devices? Second question is the temperatures were correctly showing as it should for a few days, and after trying to change the sensor, it disappeared and only showed "Not used" in all three sections and no sensors to chose from. I tried re-detecting drivers as well as a complete re-install of the app and still no avail. A few minutes ago, it showed up as the server had been rebooted, but it disappeared again immediately after clicking apply. Any solutions?
(Sorry, this is the first time I am using these forums, so I may have this in the wrong topic or something.)
Edited by Tech4KStudios
Yes
Have you tried on the support thread I linked?
You can always go directly to the correct support thread for any of your plugins by clicking on the Support Thread link for it on the Plugins page.
