June 26, 20197 yr I have struggled with this for a while now, and no matter what I do I seem to fail mounting drives outside unraid array with correct permissions. So for the first and maybe most important question: Is there something that needs to be enabled to be able to use disk mounts outside Unraids array in a VM over 9p? If I mount any of the unraid array folders like /mnt/cache or /mnt/user/, I get expected permissions and can read and write and everything is wonderful. But if I then try to mount something like /mnt/disks/Cache (for a new external cache drive), or another /mnt/disks/Data folder which is both assigned via the "Unassigned devices" plugin, I get only read access except from creating files under root in the VM. I have checked the folders both when mounted and not, they all share the same user:group and chmod values. The fstab and mtab is exactly the same and I can't find any useful information in the log files either. I also tried to make a folder under root, chown it to myself with permissions telling me I should have no problems writing a file in it, but it still denies it. It must be something I really have overlooked, maybe something stupid and tiny - because I feel I've been through more of the "advanced" shit already. FSTAB: storage /mnt/storage 9p trans=virtio,version=9p2000.L,msize=262144,_netdev,rw 0 0 media /mnt/media 9p trans=virtio,version=9p2000.L,msize=262144,_netdev,rw 0 0 scratch /mnt/scratch 9p trans=virtio,version=9p2000.L,msize=262144,_netdev,rw 0 0 cache /mnt/cache 9p trans=virtio,version=9p2000.L,msize=262144,_netdev,rw 0 0 MTAB: storage /mnt/storage 9p rw,sync,dirsync,relatime,trans=virtio,version=9p2000.L,msize=262144 0 0 media /mnt/media 9p rw,sync,dirsync,relatime,trans=virtio,version=9p2000.L,msize=262144 0 0 scratch /mnt/scratch 9p rw,sync,dirsync,relatime,trans=virtio,version=9p2000.L,msize=262144 0 0 cache /mnt/cache 9p rw,sync,dirsync,relatime,trans=virtio,version=9p2000.L,msize=262144 0 0 "cache" is the only one which is troubling, and the only one outside the Unraid array. I have similar problems with another VM where I chose to run NFS instead, but I guess I would prefer to use 9p as long it is on the same machine. I could not find anything more about this specific problem on this forum, and I have been through multiple posts here already and tried like everything as setting gid,uid etc.
September 25, 20206 yr It only works if you're on the same network! I know this is an old thread, but I'm looking and can't find anything to solve the same issue you were having. I'm having the same issues. I tried it, and it works on the array, but I can't seem to get it to work on an unassigned drive. The permissions won't let me do anything unless I use sudo, which isn't a solution. Problem for me is that I'm passing through a nic with a different WAN, so I'm not on the same network as my unraid box, and I really need to be able to write to an unassigned drive passthrough-mounted. Seems like it should be an easy deal, but it is totally not! Edited September 25, 20206 yr by woodmister
