September 19, 20196 yr Hi all. This is my first post. I have been a Unraid user for about 6 months with virtually no problems. Most recently, I had installed Heimdall and followed Spaceinvader One's tutorial on setting up an NGINX proxy with a custom domain. A few days later, I woke up to find the server down. Restarting was futile, and the USB key was fried. I transferred my key to a new USB, and luckily had an old backup of my old USB which I used to get the server back online. It started up, and I immediately shut down the array and ran a check - no errors. However whenever I bring the array online, the system crashes shortly after. If I leave the array down, there is not an issue (it can stay on for a while without crashing). I was able to download server diagnostics and I have a syslog (as well as all the other files which I am happy to share). The system won't stay on for long, maybe a few minutes. Fix common problems intermittently shows a hardware error. I've never had a hardware problem until now, so not sure why I would have one now. Any help would be tremendously appreciated! EDIT: Attached also find two recent diagnostic zips. syslog.txt tower-diagnostics-20190918-2147.zip tower-diagnostics-20190917-2017.zip Edited September 19, 20196 yr by razorweb
September 19, 20196 yr Community Expert I don't see anything obvious in those. 10 hours ago, razorweb said: I immediately shut down the array and ran a check - no errors. By "check" do you mean a parity check? Just a word of advice on using the forum. When you edit a post, for example, to attach those diagnostics, the thread doesn't show up as having anything new in it for the rest of us. The only reason I even looked at this thread again is because you had made a new post to it. If you hadn't, I would likely have forgotten all about it since I read a lot of threads and only look for those that have new posts in them. So, it is best to put new information in a new post or it could be overlooked by the people who are trying to help you.
September 19, 20196 yr Author Thanks. Sorry about that. Yes, parity check came back ok. I skimmed through the log and found the following errors: Sep 19 19:47:39 Tower nginx: 2019/09/19 19:47:39 [error] 5082#5082: *1669 upstream prematurely closed connection while reading response header from upstream, client: 192.168.1.24, server: , request: "GET /webterminal/ HTTP/1.1", upstream: "http://unix:/var/run/ttyd.sock:/", host: "192.168.1.3", referrer: "http://192.168.1.3/Dashboard" Sep 19 19:49:00 Tower root: Fix Common Problems Version 2019.09.08 Sep 19 19:49:05 Tower root: Fix Common Problems: Warning: Template URL for docker application deluge is missing. ** Ignored Sep 19 19:49:05 Tower root: Fix Common Problems: Warning: Template URL for docker application heimdall is missing. ** Ignored Sep 19 19:49:05 Tower root: Fix Common Problems: Warning: Template URL for docker application jackett is missing. ** Ignored Sep 19 19:49:36 Tower kernel: mce: [Hardware Error]: Machine check events logged Sep 19 19:49:36 Tower kernel: [Hardware Error]: Corrected error, no action required. Sep 19 19:49:36 Tower kernel: [Hardware Error]: CPU:3 (17:8:2) MC3_STATUS[-|CE|MiscV|-|-|-|-|SyndV|-]: 0x9820000000000150 Sep 19 19:49:36 Tower kernel: [Hardware Error]: IPID: 0x000300b000000000, Syndrome: 0x000000002a000503 Sep 19 19:49:36 Tower kernel: [Hardware Error]: Decode Unit Extended Error Code: 0 Sep 19 19:49:36 Tower kernel: [Hardware Error]: Decode Unit Error: uop cache tag parity error. Sep 19 19:49:36 Tower kernel: [Hardware Error]: cache level: RESV, tx: INSN, mem-tx: IRD any thoughts?
