Problem with docker container in unraid 6.8.2 (need help)
If i use the either "steam lan cache" or "steam cache bundle" they seem not to work with unraid 6.8.2 (prob im doing something wrong), but they did work with unraid 6.7.1 (@100mbps) and as i updated to 6.8.2 i did a fresh install formatted all drives (cause im still in the setup stage) and opted to use the 10gbps connection only, SMB works fine from my pc's ssd to the array about 550mb/s and thats cause the ssd's speed is 550mb/s read also i know the box has internet connection cause i installed the docker containers
i did tried lot of settings and ip's and docker container network modes, also i really dont want to go back to 6.7.1 cause the smb was a bit wonky for me there and cause the docker speed was as fast as my connection so no win there
Model: Custom
M/B: ASUSTeK COMPUTER INC. Z10PA-D8 Series Version Rev 1.xx
BIOS: American Megatrends Inc. Version 3801. Dated: 08/23/2019
CPU: Intel® Xeon® CPU E5-2603 v4 @ 1.70GHz (2 of them)
HVM: Enabled
IOMMU: Enabled
Cache: 384 KiB, 1536 KiB, 15360 KiB, 384 KiB, 1536 KiB, 15360 KiB
Memory: 64 GiB DDR4 Multi-bit ECC (32gb per cpu)
Network: bond0: fault-tolerance (active-backup), mtu 1500
 eth0: interface down
 eth1: 10000 Mbps, full duplex, mtu 1500
Kernel: Linux 4.19.98-Unraid x86_64
OpenSSL: 1.1.1d
Edited by onureemus
